1978 - 1996 Big Bronco
Cold Start & Idle
Old Jan 3, 2006 | 06:20 AM
citterly's Avatar
citterly
Cold Start & Idle
Hey Guys,
Since installing some upgrades to my '92 Bronco, it's having some trouble in the colder weather. On initial start, the truck starts right up, idles @1100 then dies when fast idle kicks off. Re-start idles @1400 then is ok @ 600 when fast idle kicks off.
My motor has the following:
5.0L 302 HO
Stock Heads w/ short side raius porting
Comp Cam 35-255-5
Summit Shorty Headders
Stock Y-Pipe
Open Cat
Single Flowmaster
I'm guessing the engine is flowing better now and has thrown off the speed density mappings, but that's just a guess.
Thanks for your suggestions.
Chris
Old Jan 4, 2006 | 07:03 AM
citterly's Avatar
citterly
Anyone? Bueller?
Old Jan 4, 2006 | 07:28 AM
BillyBob69's Avatar
BillyBob69
IAC? Idle air control valve? Usually the first thing I look at when it comes to idle problems.
Old Jan 4, 2006 | 08:22 AM
muckypaws's Avatar
muckypaws
first thing, check for codes. This will save a lot of guess work.
I have the full Ford manual for 92s so if you get the codes and any other symptoms I should be able to sort out a full troubleshooting guide from it.
Simon
Old Jan 4, 2006 | 05:23 PM
citterly's Avatar
citterly
I checked for codes in the late November time frame, nothing came up. I'll try again and see if there is something stored since.
The truck runs great otherwise, just anything below, I'd say 35°F gives it problems for the first couple minutes.
Thanks
Chris
Old Jan 4, 2006 | 05:51 PM
imlikeojnow's Avatar
imlikeojnow
check for vaccuum leaks and also check your idle air control valve. you can check it with a 9 volt battery. just get some wires and hook them up to the leads and then hook it up to the leads on the idle air control valve if it is good you will here the cork pop.
Old Jan 11, 2006 | 06:37 AM
citterly's Avatar
citterly
Just wanted to follow up with the resolution. Talking to the guy at the parts store he suggested a coolant temp sensor, it was cheap, $16 compared to $65 for the idle air control valve. So I went for the coolant temp sensor since it was probably never replaced anyway. The truck starts gret in the morning now. He also said that it could help my mileage. I filled up the tank last night, so if things look good there as well, I'll let you all know.
Thanks!
Chris
