Replacing oil pan, can't raise engine...
Old Jan 9, 2006 | 06:05 PM
DT 466Man's Avatar
DT 466Man
wasn't too hard for me the first time i did it. didn't mess with anything other than the 2 large nuts that secure the engine mounts to the frame, and the oil pan
i did it in 2 hours the first time, 2nd time was also 2 hours start to finish, but this time i replaced the bearings. i'm 17 no lift in the garage, and did it all by myself. makes me feel proud
DT
Old Jan 9, 2006 | 06:07 PM
stractor's Avatar
stractor
You will have to remove the EGR valve to get the engine to go up any more. When you do the pan will clear but will still have to be squeezed out, it doesn't just fall out, it will have to be manipulated out. You will not have to remove the upper intake.While you are in there replace the oil pump. I used a cast iron one.
stractor
Old Jan 9, 2006 | 06:13 PM
zach_barrow's Avatar
zach_barrow
Heh, yeah, I already bought a new one. In fact, I've already taken the old one out. I was able to get it out from between the bottom of the engine and the pan. Generally speaking, is the EGR easy to remove?
Old Jan 9, 2006 | 06:44 PM
stractor's Avatar
stractor
There are only two bolts on the EGR valve but that is the easy part. There is a large nut that holds the tube that goes from the valve to the exhaust manifold. I used penetrating oil on the nut and it came loose, you could also use a propane torch to heat the nut ,CAREFULLY. The problem is getting a wrench on the nut and actually turning it, there is no room to swing the wrench, you have to be a little creative. If you have the EGR valve off --replace it. Also a good time to check the tube going from the valve to the exhaust manifold, they rot out and then you have a large exhaust leak. You really don't want to try and remove the wiper motor unless you really have to.
stractor
Old Jan 10, 2006 | 06:14 AM
Citation 2's Avatar
Citation 2
I played the 3/4" shuffle a few weeks ago when I changed the oil pan gasket on my 4.9L. I finally took a claw hammer placed it on the rear of the oil pan and pulled down and it came down nice and easy.
When I put it back up, I used a bottle jack put pressure on the back of the pan and it slid up and forward.
Old Jan 16, 2006 | 11:48 PM
zach_barrow
Thanks for all the help everyone. I finally got everything back together and so far it is running well with no leaks.
Old Jan 17, 2006 | 10:05 AM
quicklook2's Avatar
quicklook2
good for you!
Cardinal
Oct 27, 2024 11:23 PM
Y2KW57
31
Apr 8, 2021 11:37 PM
kr98664
15
Sep 27, 2016 01:21 PM
32ratrod
51
May 17, 2013 01:48 PM
mike L
May 24, 2006 07:45 AM
