fuel pressure inertia switch
Old Jan 17, 2006 | 03:38 PM
pintopower8's Avatar
pintopower8
My work truck is a 4.9L 1990 efi F-150. I was wondering if I have to shut off the ineretia switch to change the fuel filter and crank the engine. The manual only said what to do if the vehicle is rolled. Also any tricky stuff or suggestions on changing this filter?
Old Jan 17, 2006 | 05:45 PM
rhetor's Avatar
rhetor
Just bleed the fuel pressure and remove the filter.
The spring clips on the gas lines are terrible and hard to get off. good luck.
Old Jan 17, 2006 | 06:57 PM
Ranger GT2's Avatar
Ranger GT2
You can unplug the electrical connection to the ineretia switch and then start the motor to bleed down the fuel pressure. Not sure on the filter connections. Does it have the plastic clips or the round connection with springs inside? Plastic clips are pretty easy to get off but you should replace them if they look bent out of shape. The metal spring type uses a tool to get the two sections apart. The tool can be bought a most auot parts stores.
