EBP sensor
Old Jan 7, 2006 | 07:02 PM
95psd's Avatar
95psd
EBP sensor
I bought the EBPS plug from Black Cloud to eliminate the p0476 code and now it is throwing the p0472 code instead. Any one have any ideas?
Old Jan 8, 2006 | 11:55 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Does your truck still have the EBPV installed? If you eliminate the sensor you'll also need to disable the valve itself. Do this by disconnecting the small two wire plug at the base of the turbo pedestal.
Old Jan 8, 2006 | 12:12 PM
95psd's Avatar
95psd
Yes it does, I have the exhaust brake mod. I was just hoping to eliminate the P0476 code because of the debate of it causing defueling or not. So now I don't know which code would be better the P0472 or the P0476? Thanks for your imput.
Old Jan 8, 2006 | 12:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
If the Check engine light comes on...it's defueled, but that doesn't mean what most people think it does. The PCM doesn't have the capacity to simply pull fue untl the engine quits, it simply selects the lowest fuel table from the five or so preset tables written to it.
If you are not truck pulling or drag racing it, then defueling is not that big of a deal...unless the light is bothering you.
Does the brake mod still work with the EBP sensor eliminated?
Old Jan 8, 2006 | 01:01 PM
95psd's Avatar
95psd
The light haas never came on. I just use my truck as a driver and to pull my 5th wheel. The switch I bought is "supposed" to eliminate the code from being thrown and not the switch, so I am assuming that the brake is still working although I have not driven it yet since I made the change.
Old Jan 8, 2006 | 01:06 PM
cookie88's Avatar
cookie88
FTE Emeritus
If the light has not come on under a load, no fueling changes have happened.
Old Jan 8, 2006 | 01:09 PM
95psd's Avatar
95psd
Ok, thank you.
firedaniel
Jan 28, 2015 08:15 PM
SunBum
Aug 17, 2011 02:24 PM
fdaugher
Apr 22, 2011 05:18 PM
rosa70
38
Sep 4, 2005 03:21 AM
