Modular V10 (6.8l)
'05 dyno #'s
Old Jan 6, 2006 | 12:26 PM
Grey Ford's Avatar
Grey Ford
'05 dyno #'s
Took it to Pure Power Performance in Victoria Texas yesterday. I was a bit surprised when we were done. Stock '05, six speed, 4.10's, SC, LB, 4x4, etc...
1st pull:
239hp
496ft lbs
2nd:
237hp
507ft lbs
The speed limiter cut in at 96mph, which was approx. 4300 rpm. I'm sure there are a few more hp lurking in the next 1000 rpm or so. The manual trans trucks also have a RPM limiter that cuts in at 5300. Never saw it.
The X-Cal 2 will be installed before I make the next trip.
Old Jan 6, 2006 | 12:31 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is there something wrong with those torque #'s or has Ford been lieing through their teeth?
Old Jan 6, 2006 | 02:22 PM
NoMo's Avatar
NoMo
Those numbers do look odd. What gear was the truck in?
Old Jan 6, 2006 | 02:31 PM
someday's Avatar
someday
is that good or bad...torque higher and hp lower...what was ford advertising exactly
Old Jan 6, 2006 | 03:05 PM
RobertH's Avatar
RobertH
Confused and ignorant here..... Why is the HP so low? Thought it was supposed to be up around 450 or so?
Old Jan 6, 2006 | 03:06 PM
krewat's Avatar
krewat
I'm wondering the same thing, although he said something about hitting the speed limiter, so it can't be 1st/2nd/3rd, gotta be 5th or 6th.
Old Jan 6, 2006 | 03:50 PM
ken04's Avatar
ken04
the speed limiter cutting in at 4300 rpm certainly killed his hp numbers, but the 496 ft lbs of tq are also confusing. The motor as suppsed to be 460-ish. Sounds like something is wrong somewhere.
Grey Ford's Avatar
Grey Ford
The truck was run in fourth gear, because that is the closest to a 1:1 ratio.
This was the first '05 the shop had on their dyno. An '04 Excursion with an auto trans made approx. 205hp.
I should have mentioned the dyno in question is a Mustang, NOT a DynoJet. DJ figures are usually a bit higher.
Krewat, the only real world numbers I have ever seen that correspond to what Ford claims have been the 5.0 in a Mustang. I'm sure they knew more than a few would wind up on a dyno!
Yes, the numbers are strange. Most dyno charts I have seen are with an auto. trans. This is a first for me too. Does anyone remember who had the last '05 on a dyno? I saw some numbers not to long ago, but cannot think who it was.
I think I'm going to e-mail the printouts to Lonnie, and see if he can shed any light on what we are seeing.
Edit to add- Sorry, brain fart. It was run in fifth. I ignore 'low' gear due to the fact it is useless unless pulling an extremely heavy load. I really consider it a five speed as does Ford due to the way the numbers on the shift **** are printed.
Old Jan 8, 2006 | 01:23 PM
captchas's Avatar
captchas
Guest
i had the same speed problem .we had to make all the pulls holding my auto back in 3rd till we got the ecal 2 tuned and set.
base line stock on mine was 248.8 hp and 293.2 torqe with a bad senser not letting mine go into full throttle inrichment. the excal2 took care of many of fords little hold em backs.like the auto trans torqe limiting program. some thing your shop should able to over come. check out my gallery. for some toys that helped. on a p.s those dyno numbers where me and nisar
Old Jan 9, 2006 | 03:47 PM
biz4two's Avatar
biz4two
Originally Posted by Grey Ford
1st pull:
239hp
496ft lbs
2nd:
237hp
507ft lbs
Interesting. Those are some killer torque readings for sure. How many miles on your '05 V10?
biz
Old Jan 10, 2006 | 11:32 AM
concretecamper's Avatar
concretecamper
Those numbers can't be at 4300 RPM's....the HP numbers would be alot higher at those torque figures running at that high RPM. I'm confused.......
Old Jan 10, 2006 | 05:35 PM
Grey Ford's Avatar
Grey Ford
Like I said, they look strange.
I have an appointment with a shop in San Antonio next week for a couple of pulls. Maybe we can figure out wtf is happening.
Could be the first shop's dyno needs a dyno tune.
Old Jan 10, 2006 | 06:44 PM
captchas's Avatar
captchas
Guest
i hope so as you are the first with a stick shift to roll a 05 on a dyno. get that excal2 and kill the speed stop so you can roll it better.
outofcontrolreb
Apr 23, 2019 03:38 PM
gui88ford
2009 - 2014 F150
33
Apr 5, 2007 11:07 PM
hang10
Modular V10 (6.8l)
23
Aug 7, 2003 12:56 PM
99Guy
4 Cylinder Engines
Jan 5, 2003 01:19 PM
DeenHylton
May 2, 2001 10:29 AM
