Dashboard Problem?
Old Jan 5, 2006 | 05:54 AM
TexasGuy001's Avatar
TexasGuy001
Dashboard Problem?
My 95's dash has a small problem. There is a black plastic ear or tab on the passenger side right next to the kick panel. It has cracked and is no longer connected. It was making a lot of noise, so I loosened it and moved the tab over. The noise is gone, but the dash still is just barely loose on the passenger side. It occassionally makes a small creaking noise. I would like to fix this, but don't really know where to start. Is there something like JB Weld that would work for plastic, or do I have to replace that under-dash bracket/support? Maybe I could somehow make a new one. Does anyone have any ideas or experienced this little delima before? I have a picture of what I am describing, but could not find a way to add it to this post.
Old Jan 5, 2006 | 09:49 AM
JoeVB's Avatar
JoeVB
If you email me your picture (through this forum) I can get a better idea but my suggestion is to use epoxy as the glue. I have been using this for about 5 years now and it will work on anything (unless the surface wasn't clean when you put it on). I use the 5 or 30 minute, works great.
I glued a magnet (used as a sensor for after market cruise control) on my drive shaft. I tried everything including JB Weld. That would hold for a summer. Once I tried epoxy and it held for 2 years.
Joe
Old Jan 6, 2006 | 02:07 PM
clerk's Avatar
clerk
My 93 had the same problem with the dash mounting point on the passenger side. I made a small steel angle bracket and bolted it in place and then with the dash at the proper level used self tappers to fasten to the kick panel steel post. Has been holding now for over threee years.
Old Jan 6, 2006 | 11:03 PM
BuddyFord's Avatar
BuddyFord
call the nearest dealership and get the official FoMoCo repair kit, part no. F4TZ-1504366-A I used it. 30 minutes and the dash was good as new. no more squeaks, and the pass. end stopped bouncing on gravel roads.
Old Jan 7, 2006 | 05:44 AM
TexasGuy001
Hey,
Thanks for all of the input. I was originally going to use epoxy. I actually bought a few things from the hardware store to do the angle bracket idea. However, if there is an official repair kit, I am going to give that a try first. I'll probably get that on Monday. What all is included in that? I bet it is a special order deal right? I hope its an inexpensive fix. Does it cost much?
Old Jan 7, 2006 | 07:04 AM
subford's Avatar
subford
Hey,
You get a one, steel, double angle bracket, three pop rivets, and a set of installation instructions all in a box.
Yes they did have to order it and it cost $18.72 plus Tax for a total of 20.09 as of 11/04/05.
Took about two days to get it and with out this number they did not know what I saw talking about. Part # F4TZ-1504366-A
Old Jan 7, 2006 | 08:57 PM
TexasGuy001
Thanks, I'll definitely be ordering that kit on Monday. Thanks again for all of the input.
Old Jan 7, 2006 | 09:08 PM
quicklook2's Avatar
quicklook2
i used epoxy and metal screen than another coat of epoxy.
2 years and it holds perfect still and it was way cheaper than $20.
i let it harden for a day
i had both the epoxy and screen already.
Old Jan 11, 2006 | 10:19 AM
flair94's Avatar
flair94
I'm glad I search before asking this question. Mine is broken in the same place on my 94. Thanks for the help that I didn't ask for.
Old Jan 11, 2006 | 12:14 PM
minnesota4x4's Avatar
minnesota4x4
This must be a common problem, my 95 is broke also. Thanks for a solution.
Old Jan 12, 2006 | 11:09 AM
02FordFx4's Avatar
02FordFx4
How much did you order the repair kit from Ford for? The passenger side on my 94 bounces and cracks all the time. Thanks for the solution. This site is great.
Old Jan 12, 2006 | 11:22 AM
subford's Avatar
subford
How much? See my post above.
Old Jan 12, 2006 | 08:32 PM
02FordFx4's Avatar
02FordFx4
Sorry the post had changed since I last looked but thanks I will be ordering that this monday too. Hope they don't run out with all the people reading this.
Old Jan 13, 2006 | 07:34 AM
flair94's Avatar
flair94
Smile
I live in Southeastren PA and called my local dealer. For the repair kit, F4TZ-1504366-A they wanted $27.12 + tax and it had to be ordered. There is another dealer I order from that I found on the web that is in Kent, Washington. For the same part they wanted $13.48 + $7.50 shipping. Again I save by using them instead of buying local. I do recomend them and have no problems with ordering or receiving parts form them. www.1stfordparts.com/partscat.html. I am now waiting for the part.
Dennis
billyrb
WTB - Parts & other
Oct 15, 2015 12:55 PM
gdubia
1997 - 2003 F150
Apr 18, 2012 05:21 PM
mkain
Oct 5, 2011 08:37 AM
IT_Dude
Jan 10, 2011 09:59 PM
climat
1978 - 1996 Big Bronco
15
Aug 24, 2008 10:10 AM
