Truck Wont start, any help?
I have an 02 F250 Superduty v10, My third brake light was out and I replaced the bulb and that didn't fix it, so I pulled the fuses one at a time to see if any of those were bad.
Now I can't get it to start. It's as though the truck doesn't even recoginize that the key is even there.
I don't have any security systen that I know of.
I can turn the key and none of the guages move, none of the idiot lights come on, the door chime doesn't shut of after the key is in the on position.
I checked the fuses with a test light to see if they were all getting power and 9 of them have no power no matter what position the key is in.
Fuse Position.....Description
#09.................Heated Mirrors...................don't have these anyways
#22.................Engine Control
#23.................Engine Control
#31.................Clutch Interlock Switch.......not sure wht this is
#32.................Radio (start)
#43.................Fog Lamps
#44.................PATS Module, Transceiver...not sure what this is
#45.................Ignition switch Run/ Start feed
The truck does turn over, but does nothing else.
If anyone has any idea what might be the problem, your advice would be greatly appreciated.
Thanks
Thanks
Actually, thanks for getting back with the results. I'm personally confused too as to how the system would have had a clue about any mis-installed fuses (unless there's an extra contact, etc). But your experience of getting no response with any of the accessories, and that it might be the fuses, is very interesting. Thanks for the update!
