Magnetic drain plug
Old Jan 4, 2006 | 02:52 PM
clintbonnie's Avatar
clintbonnie
Magnetic drain plug
In changing my oil in my 99, I just noticed for the 1st time that my drain plug is magnetic... I was a bit surprised. I was looking on the internet for a magnetic drain plug for a SD and I had one and did not know it. So i guess it should be inspected and cleaned during an oil change.. Just thought I would pass this along..
Old Jan 4, 2006 | 03:56 PM
Kwikkordead's Avatar
Kwikkordead
Good to know. Thanks for passing it on.
Old Jan 4, 2006 | 04:56 PM
dagren99's Avatar
dagren99
Smile Magnetic Plug
My 00's plug is magnetic as well.
DG
Old Jan 4, 2006 | 08:01 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Hopefully it doesn't require cleaning. Metal on the mag is never a good sign.
Old Jan 4, 2006 | 08:11 PM
Orezona's Avatar
Orezona
Maybe it was on the 6.0 forum or something else but, somebody was asking since the stock plug is magnetic and the Fumoto drain valve is not would it be ok to use? What you gurus think?
Old Jan 4, 2006 | 08:20 PM
cookie88's Avatar
cookie88
FTE Emeritus
I guess it would depend on why the drain valve was installed. If the folks installing them are doing so to make getting oil samples easier, then the report would do more than the mag plug could.
FordFETruck
Apr 6, 2012 08:17 PM
thbowen
Apr 24, 2009 06:02 PM
texas_vet
Feb 20, 2006 10:40 AM
jfsully
Oil & Lubrication
Feb 18, 2006 06:35 PM
clintbonnie
Aug 8, 2005 02:38 PM
