Charging System Failure
Old Jan 3, 2006 | 12:27 AM
BILLYBAD_1's Avatar
BILLYBAD_1
Just Picked Up A 1985 Ford F-150 4x4 With The 300 I. Guy Told Me That It Needed A New Alternator. Purchased And Installed New Alt. Battery Ended Up Going Dead. Put In Another Battery(not Brand New But Good) And That One Went Dead. Any Advice From Someone Who Has Had Similar Problems Would Be Great. Next Step I Guess Is To Put A New Voltage Regulator On It. Also There Is A Wire That Comes Off The Voltage Reg. And Runs Down To The Alt. That Has A Non Replacable IN-LINE Fuse. Could That Be The Problem Also?
Old Jan 3, 2006 | 12:52 AM
Violjohn78's Avatar
Violjohn78
I had voltage regulator go bad and it was shorting and causing the battery to drain. easy way to check the fusable link is to check for continuity of the wire from the regulator through that to the alternator..easy fix is to replace the regulator and see what happens.
Old Jan 3, 2006 | 01:02 AM
ford390gashog's Avatar
ford390gashog
you should always replace the VR when a new alt is installed. and make sure the VR is grounded before the battery is rehooked up.
Old Jan 3, 2006 | 09:32 PM
NvMyWS6's Avatar
NvMyWS6
Make sure the belt is in good condition. My 86 had charging problems and it ended up being the belt was slipping.
LWolffe
Aug 25, 2014 05:12 PM
ZombieSlayer
1978 - 1996 Big Bronco
Feb 15, 2014 11:34 PM
Pitcrw6
Aug 26, 2012 12:59 PM
maconman50
Oct 9, 2011 12:20 AM
mikehalll
Jan 12, 2007 09:26 AM
