What limits the boost?
Old Jan 2, 2006 | 06:58 PM
Banshee Ben's Avatar
Banshee Ben
When running hard the boost will fly to 30 and do a dead stop, which is great but there is no waste gate. Is that just all the boost that turbo will make with the factory fueling.
Old Jan 2, 2006 | 07:00 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
The VGT valve.
Old Jan 2, 2006 | 09:29 PM
Banshee Ben
If the VGT limits it then why do tuners allow more boost. Seems that with the extra fuel it would just get to 30 psi faster then level out.
Old Jan 2, 2006 | 10:20 PM
SpartanDieselTech
Former Vendor
There seems to be alot of confusion concerning both the basics of turbocharger operation, and moreso, the operation of a variable geometry turbo here at FTE.
I'll work on a comprehensive explanation of how it works and post it here if you like, but give me a few days
Old Jan 2, 2006 | 11:16 PM
King of the Road 04's Avatar
King of the Road 04
Go for it, god knows we can all use some help haha.
Old Jan 2, 2006 | 11:25 PM
Cowboy Brett's Avatar
Cowboy Brett
I'm pretty sure that it's the computer that limits your boost. In the interest of honesty, I have to say I don't know what the maximum amount of boost is for the VGT Turbo on the 6.0, but I know it can go higher than what the factory programming gives you.
When the computer thinks the boost is too high, it'll just back down the VGT valve to cut the turbine speed down.
The computer knows what the bost is and what the available exhaust backpressure is. The computer will adjust the pitch of the exhaust-side turbine blades with the VGT valve to get the desired boost. The idea is a mort consistent boost level even as backpressure varies.
The VGT helps ease some of the physical limits of a conventional turbo. Turbo lag is all but eliminated. It also puts the control of the boost curve into the hands of a computer, which means you can fool with it just as you can with the fuel curve or perhaps the timing curve on a gasser.
Old Jan 2, 2006 | 11:30 PM
King of the Road 04
I second that cowboy
Old Jan 3, 2006 | 03:42 AM
Banshee Ben
I guess I'm just impressed with the responce the veins have then, I can nail it and it will fly to 30 then dead stop, I would have figured it would have momentarily passed 30 for a few then leveled off, It just acts like a gate has fully opened instantly. If a programmer can change this curv than can you make the programmer limit boost in the same way then? I like the idea of adding more fuel all over but also don't like the idea of overboosting, If you could get a program to add fuel all over and still limit boost at 30 ish than that would be great. imo
Old Jan 3, 2006 | 06:51 AM
PSD6litre40's Avatar
PSD6litre40
You must have an 03 MY Engine to be getting that much boost out of a stock truck.
Old Jan 3, 2006 | 05:41 PM
Banshee Ben
9/04 build date. Guage taken off intake elbow plenum.
Old Jan 3, 2006 | 07:14 PM
wb6anp's Avatar
wb6anp
highest mine has ever gone on factory gauge is 28 05MY build date 10/04
Old Jan 3, 2006 | 09:38 PM
towpigg's Avatar
towpigg
mine is an 05 and i hit 32.5 is that because of my exhuast
Old Jan 29, 2006 | 09:03 AM
Tdusseau's Avatar
Tdusseau
And is there a way to trick the sensor? I D/C'ed the EGR and my boost cuts out at about 20-22psi, now that sucks! EGR con, yeah high 20's low 30's. Need a way to bypass this problem. Oh yeah opened exhaust no cat/muffler. '05 cc/sb
Old Jan 30, 2006 | 07:56 PM
JeffreyK's Avatar
JeffreyK
I've never noticed anything past 20 on my factory gauge in my '05? Am I missing some power?
Old Feb 4, 2006 | 11:21 AM
jhgr's Avatar
jhgr
My truck is an 05 and the factory boost gauge will hit 25 easy.
64ponton
Dec 5, 2007 08:47 PM
Chance_Thomas
Apr 24, 2007 03:10 PM
mcbryant
May 15, 2003 05:49 PM
mcneal
Feb 15, 2001 06:50 PM
