Sponsored by: Auxito
Brake pedal doesn't return
Old Jan 1, 2006 | 10:42 AM
jww233's Avatar
jww233
I got in my truck last weekend and when I started driving the brake pedal does not return all the way, it stays down and the brakes are dragging. So far I have replaced the power booster, master cylinder and both rear cylinders(stuck bleeder valves) and bled all 4 wheels but still have same problem. Any ideas?
Old Jan 1, 2006 | 11:06 AM
peppermrj's Avatar
peppermrj
check under the dash and make sure nothing (wires, brake switch etc.) has fallen down restricting the pedals return. Did you replace the vacuum li8ne and check valve?
Old Jan 2, 2006 | 09:21 AM
preppypyro's Avatar
preppypyro
How hard of a job was it to change the master cylinder?
Old Jan 2, 2006 | 04:23 PM
jww233's Avatar
jww233
The master cylinder was pretty easy to change, the vacuum booster was a pain in the butt, it is a very tight fit.
Old Jan 2, 2006 | 04:24 PM
jww233's Avatar
jww233
Turned out the problem was pedal itself was sticking, loosened up the bracket and sprayed with lubricant, works fine now.
Old Jan 2, 2006 | 05:14 PM
peppermrj's Avatar
peppermrj
Cool! Thanxs for the update.
F150III
Feb 14, 2017 09:30 PM
kr98664
Nov 12, 2016 09:04 PM
R&RFord
Jul 27, 2016 06:21 PM
carnut122
27
Sep 16, 2015 09:36 PM
hankviii
Aug 4, 2015 10:58 AM
