Brake pedal doesn't return
Old 01-01-2006, 10:42 AM
jww233's Avatar
jww233
jww233 is offline
I got in my truck last weekend and when I started driving the brake pedal does not return all the way, it stays down and the brakes are dragging. So far I have replaced the power booster, master cylinder and both rear cylinders(stuck bleeder valves) and bled all 4 wheels but still have same problem. Any ideas?
Old 01-01-2006, 11:06 AM
peppermrj's Avatar
peppermrj
peppermrj is offline
check under the dash and make sure nothing (wires, brake switch etc.) has fallen down restricting the pedals return. Did you replace the vacuum li8ne and check valve?
Old 01-02-2006, 09:21 AM
preppypyro's Avatar
preppypyro
preppypyro is offline
How hard of a job was it to change the master cylinder?
Old 01-02-2006, 04:23 PM
jww233's Avatar
jww233
jww233 is offline
The master cylinder was pretty easy to change, the vacuum booster was a pain in the butt, it is a very tight fit.
Old 01-02-2006, 04:24 PM
jww233's Avatar
jww233
jww233 is offline
Turned out the problem was pedal itself was sticking, loosened up the bracket and sprayed with lubricant, works fine now.
Old 01-02-2006, 05:14 PM
peppermrj's Avatar
peppermrj
Cool! Thanxs for the update.
F150III
02-14-2017 09:30 PM
kr98664
11-12-2016 09:04 PM
R&RFord
07-27-2016 06:21 PM
carnut122
27
09-16-2015 09:36 PM
hankviii
08-04-2015 10:58 AM
Quick Reply: Brake pedal doesn't return
