rebuilding my engine
Old Dec 31, 2005 | 06:24 PM
gearhead0211's Avatar
gearhead0211
Question rebuilding my engine
since i hydro-locked my engine i must rebuild it. soo i need all the torque specs for my 1996 4.0L V6 explorer engine if anyone has these it would help me alot.
thanks
Old Dec 31, 2005 | 11:54 PM
Jharger's Avatar
Jharger
Was this part of the thread I read yesterday - maybe in the engine forum? Goinig through a 3 foot puddle.
If you are going so far to pull and rebuild the motor, get a haynes or chiltons manual.
Old Jan 1, 2006 | 12:20 AM
ford390gashog's Avatar
ford390gashog
being that you hydro locked it , you bent probably every rod. the machine work on that engine and new rods will set you back 1500-1900 easy. that engine can't be overbored to easy and most of the time will require sleeves. the parts for it will also be another 1500.00. you need that blocked checked for cracks and the pistons may have slight fractures in them.
Old Jan 1, 2006 | 12:23 AM
ford390gashog
a new engine runs 2200.00. you also may need new heads as those are considered throw away units. most rebuilders use new head castings and so does ford on its reman enignes.
Assaver
Feb 8, 2017 08:22 AM
dtgl90vt
Jun 21, 2016 06:29 PM
dpatterson200544
Dec 29, 2013 08:38 PM
kc7smo
Utah Chapter
Oct 6, 2013 02:12 PM
shredder1223
Apr 25, 2008 06:15 PM
