390 head rebuild
Old Feb 5, 2017 | 01:06 PM
Assaver's Avatar
Assaver
390 head rebuild
Is there a kit available for rebuilding heads? I have a stock 390 in my 76 F350. I'm just looking for a quality stock rebuild. Everything I have found so far is complete engine rebuild kits.
Old Feb 5, 2017 | 02:17 PM
fe390pc's Avatar
fe390pc
Yeah that's what I have seen as well. Do you have the D2TE heads? Those are the ones with hardened seats already. If not find some as they won't last with the unleaded fuel.
Old Feb 5, 2017 | 02:32 PM
Assaver's Avatar
Assaver
I'm not sure what they are yet. I'll have to locate the code on the heads and find out.
Old Feb 5, 2017 | 03:13 PM
HIO Silver's Avatar
HIO Silver
No kits that I know of.. every head may or may not require everything to be replaced.
Btw, you're likely better off ditching those OEM heads and going aluminum. Compare Eddy RPM heads (PN 60069 about $1300 per pair) to the labor and materials involved with rebuilding stock heads (seats, guides, seals, springs, retainers, lapping, assembly, etc.) and you'll likely find that for a few hundred dollars more will result in significant performance and efficiency gains.
... and that's my nickel.
Old Feb 5, 2017 | 06:11 PM
Blue and White's Avatar
Blue and White
I'll just add most of the cost to rebuild heads is machining. There are lots of ways to do it and different outcomes. What is required depends a lot on current condition of the heads.
Inspection by a competent and trust-worthy machine shop would give you a good idea of needs and choices you can make. As HIO said, full re-build of a tired set of heads for new or better durability can be very spendy. If the heads are in unusually good shape or you make some lower cost choices, can be a lot less. I had a budget rebuild done on a set of iron heads years ago and they lasted 50k miles. I was delighted at the time.
Old Feb 5, 2017 | 06:33 PM
crazy96863's Avatar
crazy96863
Dang where are you guys getting your heads done at? They usually cost me around $300 or so for the pair. For this price, I don't even look up the cost of parts.
Old Feb 6, 2017 | 06:13 PM
Blue and White
If he was not so far away, the OP would probably like to talk to your shop! $300/pair is a good deal.
New valve seats (in case the hardening on the originals is worn through or seats sunk), new bronze guides, new valves and new springs could add quite a bit. With all that, rebuild cost would be pretty high... close to or higher than new AL heads which also breath better.
Hopefully the OP's heads are not in real bad shape and he can find a good shop to freshen them at lower cost - like $300 - for stock rebuild.
Old Feb 7, 2017 | 10:16 AM
crazy96863's Avatar
crazy96863
Maybe I have unwittingly been getting lucky with them being in good shape. Is it the FE heads that are expensive or are these costs typical for all v8 heads? I had a pair of gt40p's for a 302 done for $200 a while back and they have been running great. Granted these are a few decades newer than any FE head but still they had 300k on them.
Old Feb 8, 2017 | 07:51 AM
crazy96863's Avatar
crazy96863
Wanted to make sure I wasn't talking out my rear end here so decided to visit the machine shop I am referring to... they are currently building my 390 so a good opportunity to check in. Long and short of it is that heads do usually run in the $300-$400 range. They also seem to be well versed in older engines... they had several flat head type engines in the works. If it helps anyone, the name is Hust Bros. out of Marysville, CA.
Old Feb 8, 2017 | 08:22 AM
4x4slik's Avatar
4x4slik
On FE engines, find a shop that knows older engines. These heads are hardened, so machining Should be done to a minimum. Hardened seats are not necessary. When I took mine in, The guy says, "Oh, worken on a 390?" as I grabbed a head from the back of the truck. He did a little surface planing, put in new valve seals and a little cleaning and testing. Total cost for head work, full gasket kit, frost plugs and ARP headbolts was a little over $300.
Snowking
Sep 3, 2007 06:23 AM
josh390
17
Oct 6, 2006 09:57 PM
briansocal
Dec 10, 2005 09:27 AM
JDenver
Nov 19, 2004 11:43 AM
jaymaria
Sep 30, 2002 04:47 PM
