fuel pump or ?
Old Dec 31, 2005 | 01:30 PM
toyota1988's Avatar
toyota1988
Question fuel pump or ?
Any help at all thanks.I have an 89 ford 300 six 5spd.4x4. EFI. I drove down to local hardware store to get horse feed. Turned my truck off came out and the truck will not start. Had to tow home. I can spray starter fluid in it and it will crank but then die after it has burned the starter fluid.I thought it was the pump so i took the fuel pump off the frame and connected it to 12 volts and it works.However when i check the connectors that go to the pump im getting to juice. I had my wife turn the key on so i could check it within a few seconds just in case the relays or anything cut my juice off but nothing there.Not sure where to start at now. Stumped waiting for any replys .thanks for any help..
Old Dec 31, 2005 | 07:47 PM
subford's Avatar
subford
I would try resetting the Inertia Fuel Shut-off switch first. Just push down on the button on top of it.
Here is a diagram of your system.
http://www.autozone.com/images/cds/g...3d800a3a48.gif
Old Dec 31, 2005 | 07:56 PM
Ford_Six's Avatar
Ford_Six
If you have power at both pumps, then chances are one is bad. Pull the lines off the inlet of the frame pump, put them in a clear container, and turn the key. If you get fuel, then the frame pump is bad. If there isn't any fuel, the problem is the tank pump, but the fuel pressure should be checked still to make sure the frame pump is doing it's job.
This sounds pretty typical of how a pump goes, they tend to fail when shut off, rather than dying while driving.
Thanks for supplying the diagram link, subford. I'm going to post that in the diagnosis thread.
Old Jan 1, 2006 | 01:09 AM
LxMan1's Avatar
LxMan1
I agree, it could be a bad low pressure pump in the tank that is not feeding the high pressure pump on the frame.
Old Jan 1, 2006 | 11:32 AM
subford's Avatar
subford
But he said he was not getting any power to the pumps.
We need to know if his EEC Power Relay clicks when the key is turned to the on position and if the Fuel Pump Relay comes on for one second after the key is in the on position.
Old Jan 1, 2006 | 12:02 PM
LxMan1's Avatar
LxMan1
Oh, must have misread the original post. Check the green relay (fuel pump).
Old Jan 2, 2006 | 09:52 AM
toyota1988's Avatar
toyota1988
Thanks subford. i checked my inertia switch. is has not been tripped. its still set. isn't it suppose to be up if tripped? however i did try pushing it down but it seems to be still set. ive got my pump off the rail and it works but im not getting fuel from the tank pump dosn;t seem to me unless its holding in the fuel filter just before this pump.
Old Jan 2, 2006 | 09:55 AM
toyota1988's Avatar
toyota1988
Thanks ford six. How can i be sure if im getting power to intank pump or not. Im not getting none to me high pressure pump on the frame. Does it half to make a complete circuit or what.Not sure how to test it.
Old Jan 2, 2006 | 10:51 AM
toyota1988's Avatar
toyota1988
Well im gonna check for fuel at my filter before the frame pump. And check the EEC for power there i guess.Just not sure yet if i need to drop my fuel tank or not.I will post what i find. thanks subford, lxman1, and ford six.
Old Jan 9, 2006 | 08:47 AM
toyota1988's Avatar
toyota1988
Wink fuel pump or ?
Thanks for the help guys. It was a bad eec relay. Put in a new relay and fuel pumps working. My 89 is back up and running.. thanks again.
marshall5610
Jun 9, 2024 04:59 PM
epoppe4
Sep 24, 2016 06:12 PM
MonArt60
Oct 31, 2014 01:45 PM
Fiddy 6
Electrical Systems/Wiring
May 1, 2009 06:57 PM
batmanincoralville
Mar 22, 2004 11:22 AM
