Air bag light flashing
Old Dec 30, 2005 | 07:08 PM
notstirred12's Avatar
notstirred12
Howdy folks, I just signed on today, and I've already found out a ton of stuff (seems like everybody's door ajar light is messed up).
Anywho, I start my 2002 Ford Ranger, 3.0L, four speed AT, 38-somethin thousand miles, and the airbag light comes on, just like always, then after it turns off, it comes back on and flashes four times, then six times. Sometimes it stays on all the time, sometimes it continually flashes, and sometimes it doesn't come on at all. From what I've learned working on classic cars, it sounds a lot like a loose connection somewhere, but this is really the first vehicle I've worked on thats even fuel-injected, so I don't want to go poking around in there. Any help would be wonderful, even if its just what color wires I need to chase.
Old Dec 30, 2005 | 07:33 PM
mymechanic'sanidiot's Avatar
mymechanic'sanidiot
Sounds to me like its some kind of error message but more informed heads will poke in on this post and let you know. I beliegve one of your sensors is malfunctioning. Not a good thing if you have an accident.
Old Dec 30, 2005 | 10:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 30, 2005 | 10:24 PM
natebaker's Avatar
natebaker
Any prior owners/accidents? I had the same problem in mine, only I tore the ribbon in my steering wheel, lol. There are two plugs coming from your steering column to a mounting place underneath your dash on drivers side, one should be in a yellow tube (correct me if I'm wrong) and make sure that both of those plugs are secure. They will mount on a bracket. Open your glovebox and look on top of the heater plenum and you'll find a little white 'box' (for lack of a better word) and make sure that's plugged in all the way. Look under your center console/drink holder and make sure the connection is tight on the air bag controller. That's a start anyways, good luck.
Last edited by natebaker; Dec 30, 2005 at 10:25 PM. Reason: forgot a little detail
Old Dec 30, 2005 | 10:42 PM
Dave257's Avatar
Dave257
try this thread.
https://www.ford-trucks.com/forums/s...ight=airbag+46
Dave
Old Jan 2, 2006 | 08:50 PM
notstirred12
Thumbs up
Thanks, all. I fiddled with the connections under the driver seat and behind the glove-box, and now the light no longer flashes at me. I hope its because this fixed it and not because it just decided to quit flashing!
kep5niner
26
Dec 6, 2011 10:28 AM
cdrmotorsports
General Automotive Discussion
Oct 2, 2009 07:20 PM
brownfamilyracing
Aug 8, 2008 03:03 AM
Flash635
Jul 28, 2004 02:48 PM
JiveBoogle
Aug 26, 2002 02:05 AM
