Replacing Door Locks?
Old Dec 30, 2005 | 02:48 PM
Slow's Avatar
Slow
When I bought my truck it had a "donor" door on it. The guy who installed it didn't change the lock over (it was a farm truck). I'm wondering how it is you go about changing the locks on the doors? I'd like to get a set of locks from another vehicle so they are all the same and swap them all.
Thanks!
Ian
Old Dec 30, 2005 | 02:51 PM
deltasoft's Avatar
deltasoft
re:
You can prob pick them up depending on year and model of the truck at your local autoparts stores a pair. They are not much expensive, i remember i changed my past f150's door locks for new ones since they were bad.....
Old Dec 30, 2005 | 03:08 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
They are easy to replace. Just remove the inside door panels (carefully), make sure the window is rolled up, disconnect lock linkage and remove the clip that holds the lock in.
Old Dec 31, 2005 | 05:25 PM
goldnickle's Avatar
goldnickle
If you are carefull you don't even have to remove the door panel. I got a new set on line from LMC. you can even get the ignition key and tumbler with the door locks in a set if you shop around. There is a clip on the back of the door just inside the jam behind the lock, it slides out with a large screwdriver. Be carefull to protect the door when you pry it. then the lock should come out from the outside carefully remove the plastic clip [ you may have to lock or unlock the door to give you more access], and install the new one.
chuckc417
Dec 27, 2014 07:23 PM
jo15765
Sep 6, 2013 10:15 PM
fmjnax08
1997 - 2003 F150
Jan 28, 2011 02:06 AM
kahnos
Jun 12, 2006 06:13 AM
glk
Jun 14, 2004 02:51 PM
