egt sensor location??
Old Dec 30, 2005 | 02:25 PM
cwt580's Avatar
cwt580
my egt doesnt work. side pillar gauges. would the sensor be bad? How would i check? Turbo gauge works and extra oil gauge works but not egt.
Old Dec 30, 2005 | 02:32 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
have you checked the connection at the location where you tapped into the power source? how about the wires from the power source to the gauges? are they kinked, ripped, cut, anything? wiggle the gauge out of the pod, check to see if the electrical connection is good there, and if the power to the tranny temp/oil temp is wired in parallel, is a wire unhooked/missing? you check the wire that goes from the guage to the thermocouple? is the connection of the yellow and red wires good at the thermocouple?
the boost gauge will work with no electrical power (aside from lighting it) because it is mechanical.
Old Dec 30, 2005 | 03:01 PM
PSNut's Avatar
PSNut
Where did u install the thermocouple?
Old Dec 30, 2005 | 03:18 PM
cwt580's Avatar
cwt580
i didnt install. was in truck when i got it a couple weeks ago. No tranny temp/oil temp gauge. just egt,turbo, and oil pressure.
Old Dec 30, 2005 | 03:23 PM
PowerstrokeJunkie
likewise. the oil pressure is electric, if there is a wire running to a sensor for it. for it to be mechanical, there has to be an oil hose or something running to the actual gauges. they do make contraptions that measure pressure and convert it to electric for electrical gauges. look in both manifolds/uppipes to see if you can find a thermocouple sticking out of a manifold. it may Also be in the downpipe.
Old Jan 1, 2006 | 12:21 AM
mud rat jr.'s Avatar
mud rat jr.
check the thermocouple wires on back of guage as far as thermocouple location best i can say is it is in exhaust pipe near the turbo
Old Jan 1, 2006 | 07:23 AM
empiretc's Avatar
empiretc
whats your email? i will send you this cool diagram I have of the 7.3
Old Jan 1, 2006 | 06:20 PM
cwt580's Avatar
cwt580
please send me that diagram. .... i sent u my email.
might have found something today when i was installing my fogs on front. The egt module pack under dash had its ground wire pulled out. Must of happen when someone ripped out something else. Hooked it up. Guage actually reads 0 when i turn on key now. Havent tried to drive yet to see if it works. If i let the truck idle for 15 minutes should it read any temp???
Old Jan 1, 2006 | 06:24 PM
guzzle92's Avatar
guzzle92
EGTs should read 200-300* as soon as it's fired up. (pre-turbo)
rad1026
36
Oct 6, 2015 10:14 AM
hotrodfeguy
35
Oct 3, 2015 12:33 PM
Iaff113
Ford Truck Parts for Sale
Jan 27, 2015 07:43 PM
NBT22555
Jun 13, 2014 06:51 PM
jkey.bama
Apr 8, 2014 08:33 AM
