egt gauges
Old Sep 29, 2015 | 11:11 AM
hotrodfeguy's Avatar
hotrodfeguy
egt gauges
What is a good egt gauge? Also the best location to be placing one on the EX. Looking to do one here in the future.
Old Sep 29, 2015 | 12:09 PM
scotttahoe's Avatar
scotttahoe
I like Isspro, Wish the had a single gauge with dual needles for both sides though.
You want to install it in the exhaust manifold right by the oil filter.
I'll get a pic up up once I transfer it from camera to computer.
Old Sep 29, 2015 | 12:20 PM
tjmike's Avatar
tjmike
Old Sep 29, 2015 | 02:08 PM
bcg's Avatar
bcg
What app are you using? I have DiProcol EGT, Boost and Trans Temp gauges, just got Torque Pro setup and it would be great if I could get EGT and fuel pressure on the app instead. My gauges are up on the windshield by the rear view mirror but I'd pull them out if I can get it all through software instead.
Originally Posted by tjmike
Old Sep 29, 2015 | 02:28 PM
scotttahoe's Avatar
scotttahoe
From my understanding, you can not use an app for EGT and fuel psi.
Old Sep 29, 2015 | 02:30 PM
bcg's Avatar
bcg
His screenshot has EGT...
Fuel pressure is available in the Ford specific PIDs so if there was a reasonably priced app that could read those, you'd be able to get it. Auto Enginuity has it, right?
Old Sep 29, 2015 | 02:37 PM
scotttahoe's Avatar
scotttahoe
Unless he has a probe mounted somewhere wired to something (I don't know), there is no reading for EGT at the OBDII or for fuel PSI. There is fuel injector pulse width (FIPW).
In all honestly, I don't know enough about the Torque PIDs.
Old Sep 29, 2015 | 02:40 PM
bcg's Avatar
bcg
I know it's not available in Torque, they can only get the stuff that Ford is supporting through OBDII. I don't think that EGT is available through the Enhanced Ford reporting either (I've never seen it in Autoenginuity) but I fairly certain that Fuel Pressure is. I'm guessing that maybe he's hacked/customized Torque (which would be interesting to learn how to do) or that he's using an Android scantool that supports the Enhanced Ford stuff.
My Autoenginuity is pretty old so if it's the latter, I'm really interested to know what tool he's using. I'd really rather have an Android scantool vs AE since I always have my phone with me but don't always have my laptop.
Old Sep 29, 2015 | 02:48 PM
scotttahoe's Avatar
scotttahoe
That would be interesting and would like to know as well. I very well could be wrong about the fuel PSI.
Either way your going to need an EGT probe (if you don't already have one) to get a reading and this is where I drilled and tapped for mine. Right next to the oil filter driver side.
Old Sep 29, 2015 | 02:52 PM
scottddove's Avatar
scottddove
I have been looking into this as well. This is what TJmike is using I think. Check this out.
Kiwi OBD2 OBDII CAN Wireless Bluetooth Diagnostic Reader | iPhone
This is the fluid pressure devise: Fluid (Oil & Fuel) Pressure Sensor Module
This is the egt device:EGT Exhaust Gas Thermo Temperature Probe Sensor Module
I will be using dash command similar to torque pro because I have iOS equipment.
As for the fluid pressure module there is a problem. The sensor that they offer is not compatible with diesel so I found this
Amazon.com: PartsSquare 150 Psi Pressure Transducer Sender for Oil Fuel Diesel Gas Air Water: Automotive Amazon.com: PartsSquare 150 Psi Pressure Transducer Sender for Oil Fuel Diesel Gas Air Water: Automotive
I was wanting some opinions on this before I pulled the trigger on all this equipment. Are there any?
Also the cool thing about these control modules from PLX is each one can report two readings like pre and post filter fuel pressures and duel egt's. Of course this is all theory as of now but I will know in a few weeks if it will actually work. Guess I will be the Guinea pig. Opinions wanted.
Old Sep 29, 2015 | 03:04 PM
bcg's Avatar
bcg
I have an EGT probe already installed for my DiProcol gauge, I'd just love to be able to use it with something on my phone instead and remove the gauges altogether.
So far, I've found this for Android - FORScan Home. It gives a little bit more than Torque and for only about $5 is worth the price but, it isn't nearly as clean as Torque for setting up gauges so is kind of useless for that. What is nice about it though, is that it will pull DTC's from all the systems, not just those that set the SES light.
The search will continue...
Old Sep 29, 2015 | 03:05 PM
tjmike's Avatar
tjmike
You cause PLX EGT gauges with a Kiwi adapter and Torque and DashCommand.
Torque does not log EGT values
Torque gauges don't work perfectly. Notice in my photo that the digital portion of the gauge is ok but the dial and max are not.
DashCommand you have to buy DashCommand AND the Ford package ($20 total). DashCommand does not support injector pulse width as far as I can tell.
Dash command logging is goofy. You have to turn it on and off. It logs to RAM, so if the app crashes or or forget to turn logging off every hour or so you will loose your data.
I'm willing to put up with these flaws in order to get logging and the single display.
PLX sells a fluid sensor (made by Bosch) but claims it's only good for water and oil - not gas or diesel.
Torque and Dashcommand don't let you tweak the curves for sensors, so a different fluid sensor would need to have the same curve as the PLX one - or you could just accept it being off on the display and fix it in the logs with a formula.
Old Sep 29, 2015 | 03:08 PM
bcg's Avatar
bcg
Cool, thank you. I have Dash Command installed but haven't played with it much yet. I did not know about the PLX stuff or that Dash Command had a Ford kit.
Old Sep 29, 2015 | 04:59 PM
hotrodfeguy
Wow this post went fast. I have yet to buy something yet thats why I was asking.
Old Sep 29, 2015 | 06:12 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I am interested in installing an EGT probe as well, but am nervous because I have never used a thread tap and don't want to screw up the manifold and create a big problem where one does not exist now.
