oil leak
Old Dec 29, 2005 | 09:31 PM
jc2's Avatar
jc2
oil leak
I have a 1996 7.3 turbo, and just noticed a puddle of oil on the top of motor in the back any ideas of where its coming from. thanks
Old Dec 29, 2005 | 09:34 PM
1997F-350's Avatar
1997F-350
probably your turbo pedistal...
Turbo Pedestal O-Rings (between pedestal & block; pedestal & turbo)
(Ford) F4TZ-6N653-A & -B
(International) 1815560C1 & 1815561C1
Old Dec 29, 2005 | 09:38 PM
jc2's Avatar
jc2
oil leak
Thanks for the quick response.
Old Dec 29, 2005 | 09:45 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts jc2.
While you're looking around in there also check the high pressure oil lines, the actuator rod for the exhaust backpressure valve and the oil rail galley plugs along the inside of the "V" on the heads.
Old Dec 30, 2005 | 06:28 PM
jcab's Avatar
jcab
Oil Leak Also!
I"ve noticed a leak in the valley of my 97 also. What is the turbo pedistal, and how would you check to make sure that is the problem, without tearing down everything in the area first? Thanks Jeff
wheelerg
Feb 2, 2014 12:14 PM
jakegypsum
Oct 3, 2009 11:07 AM
pr
Mar 10, 2002 06:32 PM
fordmandan
Modular V8 (4.6L, 5.4L)
Jan 13, 2002 07:51 PM
tscaud
Dec 18, 2001 11:13 PM
