drive shaft
Old Dec 28, 2005 | 06:52 PM
Tomm's Avatar
Tomm
drive shaft
I heard what sounded like my transmission fragmenting at my feet, but when I jacked my '98 Ranger 2wd 5 spd up, I found a cast iron ring floating(for the lack of a better term) at the business end of my drive shaft by the transmission yolk. What the heck is that?...what is it for?...what do I have to do to replace/repair it?...and, can I eliminate it?... because I have it tied off away from the u-joint and the little truck is performing like my favorite vehicle again.
Old Dec 28, 2005 | 08:13 PM
natebaker's Avatar
natebaker
Maybe it's a seal?? Or a part of one....h
Old Dec 28, 2005 | 08:26 PM
643NRK's Avatar
643NRK
Was there any fluid leakage? Make sure the tailshaft of the tranny does not look odd.
Old Dec 28, 2005 | 08:41 PM
Ken00's Avatar
Ken00
Someone else had that happen about 6-9 months ago and they posted a pic. Can't recall what they ended up doing, I'll try searching for the thread.
Old Dec 28, 2005 | 11:05 PM
Wildpony2000's Avatar
Wildpony2000
Did you check the metal strap that holds the carrier bearing in ?
Old Dec 28, 2005 | 11:53 PM
el conquistador's Avatar
el conquistador
it is a driveshaft dampener
here is the post ken was refering to (there is a link to a picture in the first post):
https://www.ford-trucks.com/forums/s...eshaft+dampner
Old Dec 29, 2005 | 09:10 AM
Tomm's Avatar
Tomm
Thank you all for your responces, I looked at the photo you refered to El Con, and it is exactly what I had experienced. It shall be removed at my first opportunity, and I may use it as a cup holder also...Thanks again, everyone...Tomm
Old Dec 29, 2005 | 07:37 PM
CoolBenge's Avatar
CoolBenge
Tomm,
I had the same issue with my truck. In fact it was researching this problem that led me to these forums. I had a couple of people ( one guy worked at a driveshaft shop) tell me that I probably wouldn't need it. I was told the purpose of it was to help the tranny shift smoother. I don't know if that is true or not. At around 80 mph on the interstate I noticed a severe vibration. It felt like the truck was stalling. I replaced the collar and the vibration went away. If you decide you don't want to replace be sure to test drive it. The local Ford dealer priced the part at around $98.
Regards,
Tim
Old Dec 30, 2005 | 01:30 PM
Tomm's Avatar
Tomm
Thanks Tim, although I would never have the desire to drive 80 off of the race track, I think this a still reason enough to get the piece replaced due to it being that severe at 80 I'm sure 70 or 75 it is probably still doing its fair share of damage that I just don't feel behind the wheel. Appreciate the response...Tomm
dmarsh2400
13
Oct 4, 2012 12:21 AM
zrroper
Sep 17, 2012 10:49 AM
Radster
Aug 8, 2012 08:58 AM
zehcnasca
23
Nov 11, 2011 07:13 PM
drof46
Jan 22, 2008 06:16 PM
