brake problems
Old Dec 28, 2005 | 04:23 PM
pdqtimetrialer's Avatar
pdqtimetrialer
brake problems
Help! '99 Expy and the brake pedal went to the floor and the brake-idiot light is on.
Checked the resevoir and it is full.
No obvious leaks around the master cylinder or the ABS block.
I'm thinking I'll pull the wheels off and check for leaks around the calipers. But would it be a leak if the resevoir is full?
What else might be going on?
Is there a way to hook a scanner up to the ABS/brake computer?
Need to get this fixed in the next two days to be able to travel on home from the holidays.
Old Dec 28, 2005 | 06:46 PM
pdqtimetrialer
Talked more to my wife about the expy brake problem.
The brake idiot light was on because of a sensitive parking brake switch.
She said when she first started driving, she applied normal braking force but the brakes did not apply. After pumping them a few times, the brakes then worked normal. Neither the ABS nor the brake idiot light came on.
Old Dec 28, 2005 | 07:04 PM
skier-24's Avatar
skier-24
Sounds like a bad master cylinder. With no leaks, and a full reservoir there should be no air in the system to require pumping up. I had one do the same thing. It would not do it every time, but when I least expected it. Another possible symptom: Put your foot on the brake pedal and hold continuous pressure on it. If it slowly goes to the floor, the master cylinder is bad.
Old Dec 29, 2005 | 07:18 PM
pdqtimetrialer
Just got done replacing the master cylinder. Things were straight forward and there were no hiccups. The brake pedal seems a little firmer.
Thanks for the help.
Mike E.
Jun 23, 2013 04:16 AM
cowmilker08
43
Oct 20, 2009 08:32 AM
farlet
15
Jul 1, 2008 08:03 PM
sixshootingexp
Dec 9, 2005 12:37 PM
