radiator ?
Old Dec 28, 2005 | 02:37 AM
BILLYBAD_1's Avatar
BILLYBAD_1
radiator ?
i have an 85 f-150. is there any other bigger radiators i can put in it without going to the costly aftermarket?
Old Dec 28, 2005 | 02:50 AM
ford390gashog's Avatar
ford390gashog
what engine?
Old Dec 30, 2005 | 11:33 AM
BILLYBAD_1's Avatar
BILLYBAD_1
300 i. really dont want to have to go aftermarket.
Old Dec 30, 2005 | 12:30 PM
big hoss 29's Avatar
big hoss 29
I swapped a bigger radiator into an 83 F-150 with a 300-6 I had. It was a radiator for a V-8 I believe and it fit just fine. Every truck I've seen had the provision for a bigger radiator, you just have to move the mounting pads outboard to make it fit.
Old Dec 30, 2005 | 05:45 PM
mnmzimmer5's Avatar
mnmzimmer5
Any Ford small block V-8 around the same year should fit right into place...not sure about big block rad
Old Dec 30, 2005 | 06:06 PM
thenutisloose1's Avatar
thenutisloose1
Even a diesel 6.9 radiator will fit if you want it super cool lol
Old Dec 31, 2005 | 08:58 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Radiator supports are different for 300 I6's with standard cool and Extra cool, than the ones for Super cool and/or air conditioning. A Super cool Radiator will bolt right up however, just place the mounting brackets in the wider location holes provided. You will need to change the upper radiator hose to one for air conditioning or super cooling.
The difference in the supports is the hole that is in the radiator support for the radiator. The one for standard cool has a smaller hole the size of the smaller radiator, and the super cool has the wider hole like the V8's. If you put a super cool radiator in a standard cool radiator support, the hole difference will block off or restrict air going through the larger portion of the radiator etc... To get the full benefit of a larger radiator, IMO, I would switch the radiator supports with one with a bigger "hole" for the larger radiator.
To finish off the job, I would replace the fan guard with a fan shroud that will fit on the super cool radiator, and install a fan clutch if one isn't already installed for the maximum of cooling you can get.
hope this helps.
Old Jan 1, 2006 | 06:10 PM
Bdox's Avatar
Bdox
A great radiator for the Inline six is a GM crossflow from the 70's - 80's midsized rear drive V8 cars. Get one from a salvage yard and get the brackets that go with it. Easy to swap in, the hoses have the proper locations.
Of course the others options posted above a just fine too.
cowmilker08
Feb 11, 2014 09:41 AM
RobbD
Dec 3, 2013 10:04 AM
Gicknordon
Oct 3, 2012 05:48 PM
smitty7
Nov 6, 2003 02:35 PM
Shannonm1
May 3, 2003 09:00 PM
