Battery cables
Old Dec 27, 2005 | 07:29 PM
earnies2's Avatar
earnies2
Battery cables
Does any body know how thick, or thr gauge of our batt cables. I'ts time for new ones and i'm thinking about making them myself, so i can add all the extra wires i have for my accessories right into the cable instead of clamp mounted. I might put a remote mount possitive stud off the battery! but I need to know what gauge the battery wires are thanks
Old Dec 27, 2005 | 08:18 PM
PSNut's Avatar
PSNut
Not sure of the exact guage size but i'm willing to bet if u went to an electrical supply store the guy behind the counter could tell u. U can go heavier if u want.
Home Depot will carry this wire too.
Old Dec 27, 2005 | 09:29 PM
piotrsko's Avatar
piotrsko
UHHHH Home depot has House wire of the correct gauge, BUT the insulation on automotive wire is way thicker and tougher because of the vibration factor.
Old Dec 27, 2005 | 11:42 PM
stroker2's Avatar
stroker2
I know I've seen the battery wire gauge size, just can't remember it or where I saw it. I think it was 6 gauge but don't quote me on that. PSNUT is right if you took a cable to a electric supply place they could probably identify the size. I've also read that the Ford battery cables are spec'd to meet minimums and a larger cable never hurts. You might be able to get comparable cable at Home Depot if you went with a direct burial type cable. Here's a suggestion I found on Steve Baz site:
"Visit you local welding supply house and have then make up some cables for you using welding cable. This is way cheaper than Ford's fix plus it flows juice much better."
I would just say one word of caution if you're thinking of making the cables yourself. Those terminals are machined pressed on the cable and making them by "hand" will not get the same pressure applied to get really secure connections. Assuming you use a crimp type connection. A clamp type should be OK.
Old Dec 27, 2005 | 11:47 PM
jtharvey's Avatar
jtharvey
You might be able to solder the connections on though. IMHO, soldering is 10 times better than any pressed or crimped connection is.
Old Dec 28, 2005 | 07:07 AM
earnies2's Avatar
earnies2
I plan on soldering them and heat shrinking them to. I think i'm going to use 2/0 cable that should work now i only have to deceide weather to use welding cable or truck battery cable?????
Old Dec 28, 2005 | 07:18 AM
blueeyes2478's Avatar
blueeyes2478
IMO I would use welding cable.It is a little more flexable and like (stroker2) said the juice will flow better.
Old Dec 28, 2005 | 02:47 PM
PSNut's Avatar
PSNut
UHHHHH you can use heat shrink and/or rubberized electrical tape for vibration.
Old Dec 28, 2005 | 02:51 PM
PSNut's Avatar
PSNut
Originally Posted by stroker2
"Visit you local welding supply house and have then make up some cables for you using welding cable. This is way cheaper than Ford's fix plus it flows juice much better.".
Excellent idea...never thought of that approach...DANG this site comes up with great ideas!
Old Dec 28, 2005 | 09:00 PM
SpringerPop's Avatar
SpringerPop
Welding cable uses MUCH finer individual strands and many more of them. Not only will the cables be more flexible and vibration resistant, they will actually carry more current due to the phenomena known as "skin effect". There is actually more surface area (or skin) with finer strands for the same guage wire, and it's been determined that the skin is where most of the electrons flow in a wire strand.
Pop
Old Dec 28, 2005 | 09:12 PM
DALPILOT's Avatar
DALPILOT
I make battery cables all the time for marine use. Yes you can use welding cable, but welding cable is not tinned and will easily corrode in any moisture laden enviroment. I would be especially concerned about the one down to the starter.
As for soldering, it is good for stationary applications, but it brittles out the connection. In fact in marine and aviation use, crimp is the accepted methodolgy to prevent the connection from breaking at the terminal due to embrittlement.
My suggestion is to get some good marine grade wire, like 2/0 etc. Marine wire is AWG so it is a little larger that SAE you get in the auto stores. Each strand is also tinned so it will not corrode. After CRIMPING on the connectors use heat shrink with the "goo" inside. It's also available at marine stores and even comes in red. When you heat it, the goo melts and as it shrinks the goo runs out. Makes a nice waterproof seal.
Old Dec 28, 2005 | 09:16 PM
SpringerPop
That's referred to as "self-potting" shrink sleeving.
Good stuff if you can find it. Marine stores?
Pop
Old Dec 28, 2005 | 09:18 PM
PSNut's Avatar
PSNut
Good info...thanks!
Old Dec 29, 2005 | 12:16 PM
DALPILOT's Avatar
DALPILOT
Yes, West Marine or BoatUS, plenty of them near you.
Old Dec 29, 2005 | 01:02 PM
PSNut's Avatar
PSNut
I'll take a pair of custom built cables from DAPILOT and connect them to a pair of those super duper Optima batteries! can't go wrong there!
Nut
bismic
Jan 25, 2019 08:51 PM
7.3Excursion4x4
Dec 20, 2014 02:37 AM
78 & 87 Super Cab
May 20, 2014 04:27 PM
7.3pwrstke
May 17, 2014 08:21 PM
EMoeFord
Jun 4, 2007 08:49 PM
