Let'r Whistle!!!!
Old Dec 29, 2005 | 09:45 PM
kb1aah's Avatar
kb1aah
My stacks are from Grand Rock also. I haven't seen any ill effects of running without the CAT converter. The turbo sure sounds a lot nicer without the CAT.
I get asked if I have recently slipped a jet engine under the hood.
Old Dec 30, 2005 | 07:22 AM
04Muscle350's Avatar
04Muscle350
dont cut it apart. all i did was get a big drill bit and drilled some big holes into the honeycomb which lossened it up a little bit. then i got a crowbar and just knocked it out. it took under 10minute.
Old Dec 30, 2005 | 07:54 AM
keeno's Avatar
keeno
5 years back i had a ricer and took off the cat to run a straight pipe. it sounded good for a rice rocket, but i lost power. it wasnt creating enough back pressure and made the car even slower then before. does the same thing not apply with a diesel? sorry i dont know this
Old Dec 30, 2005 | 12:56 PM
XxfirmanxX's Avatar
XxfirmanxX
My buddy has a 05 with a 5" bully dog no cat sound sick and a good rummble when he get on it but he's also running the edge juice with more goodies than i can afford.I just bought the 4" MBRP turbo back with the cat delete pipe will post a sound clip when I get it installed wont be here till middle of next week.
Old Dec 30, 2005 | 04:02 PM
04Muscle350
i dont feel a lose in power at all
Old Dec 30, 2005 | 04:12 PM
big inch's Avatar
big inch
On a turbocharged engine, anything you do to free up the exhaust (or intake) will help. That is not always the case with a naturally-aspirated engine, as you found out.
Old Dec 30, 2005 | 06:40 PM
mattsf250's Avatar
mattsf250
if you have an 03, i would simply add a downpipe, and remove the muffler.
see how ya like it. this mod is about 150-200.... and sounds impossibly good, even with a functioning converter.
next, remove the cat with a test pipe, see how ya like it.
If you have an 04 to 06, you need a total 4" from turbo back, and out the back....
Old Jan 3, 2006 | 08:48 AM
cads03's Avatar
cads03
Why would an '03 be different than an '04? Does it have to do with the Variable turbo vanes?
waystro
47
Mar 26, 2016 01:47 AM
Albert Sanchez
1983 - 2012 Ranger & B-Series
May 11, 2014 06:37 PM
Christof13T
Sep 18, 2013 10:32 AM
keith57x
May 5, 2010 07:33 PM
bhaider
Oct 15, 2004 12:45 AM
