35 ring teeth 10 pinion
Old Dec 27, 2005 | 07:28 AM
jenkinsj's Avatar
jenkinsj
Is that a 3.5 gear ratio?
Jack
Old Dec 27, 2005 | 07:45 AM
holland501's Avatar
holland501
Yes it is.
Old Dec 27, 2005 | 08:02 AM
jenkinsj's Avatar
jenkinsj
I used a web site from Jeep that figured that if I have 33 in tires and a 3.5 gear ratio my rpm would be around 2100 at 60 mph. But my rpms are around 3000. Could my speedometer be off?
Jack
Old Dec 27, 2005 | 08:10 AM
The SnoMan's Avatar
The SnoMan
Jack
I get 2138 using the link below. Something is off for sure. If you did not recalibrate speedo for 33's it will be off. If you have a auotmatic too and the converter is not locking up (or it is a non lock up model) it will add about 200 to 300 RPM at that speed and RPM. Also your gearing is kinda tall for that tire size and will cause more converter "slippage" at cruise.
Click Here
Old Dec 27, 2005 | 10:49 AM
jenkinsj's Avatar
jenkinsj
It is an automatic and the tranny (C6) and transfer is out of an 84 fullsize bronco. This is in a modified 64 4x4 with a 5 liter.
Is slippage something that can be fixed? How do you tell if you have a non lock up model?
Thanks.
jack
Old Dec 27, 2005 | 10:50 AM
jenkinsj's Avatar
jenkinsj
Is there a way to recalibrate the speedo? I have seen the gear on the end of the speedometer cable.
Jack
Old Dec 27, 2005 | 03:01 PM
The SnoMan's Avatar
The SnoMan
Thanks.
jack
C6 never had a locking converter and you are on the edge of thew stall speed of it at 60 MPH with current gearing making it a bit worse. Once output shaft from converter reach about 2500 RPM the slipage is less but never goes away completely. Actaully about a 3.91 or a 4.10 gear would help and would likely put speedo dead on to with 33's (or close to it) and reduce converter slipage at cruise.
NASTseventhree
Mar 11, 2011 08:51 PM
go2toa
18
Nov 24, 2005 04:46 PM
sparky
Nov 7, 2002 08:07 PM
Eddie
Offroad & 4x4
May 24, 2001 08:14 AM
oz9609
Mar 8, 2001 12:12 AM
