The most accurate answer, but perhaps not as helpful as you probably wanted:
Maybe.
Depends on:
- Actual diameter of tire. Some 35's are only 34.4 or 34.5 inches, and they tend to fit OK. If it was truly 35.0" or bigger, it almost certainly won't clear without some trimming or reshaping.
- Width of tire
- Width and backspacing of wheel
- Cab position on frame. The cab is bolted to the frame, and can be shifted around a bit.
The BFG A/T K0 in 315/75-16 (metric version of 35x12.5) jussssst cleared my fender and bumper by acout 1/8".
