Pulling 302
Old Nov 30, 2001 | 03:25 PM
chieff's Avatar
chieff
Post Pulling 302
I am pulling an original 302 out of my 69' and I do not see any hooks on the motor in which to connect up with the motor puller. I have helped to pull a couple of newer motors that had them on the motor from the factory. Can someone tell me what to do since I am ignorant on this matter. Thanks
Chief
Old Nov 30, 2001 | 03:37 PM
dre's Avatar
dre
Pulling 302
You can either buy a carb plate, remove carb. install plate.
lift engine. Or run a heavy chain from a front head accessory
bolt to the rear of the opposite head accessory bolt and lift engine.
Old Nov 30, 2001 | 03:41 PM
dfisher1's Avatar
dfisher1
Pulling 302
Chieff,
Are you using a chain? i purchased a intake manifold plate puller. You remove the carb and bolt this plate down in place and then hook the hoist to one of three holes on the puller depending on the center of gravity. It's simple, worth about $20 and it keeps the crap out of the intake while the carb is off. What do you think?
KingFisher
Old Nov 30, 2001 | 05:50 PM
motorhead's Avatar
motorhead
Pulling 302
Lift plates for the intake are cool to use but you can do something else if you have a salvage yard near by.Look for in the '70s Pontiacs with v8s.Pontiacs usually have a couple of hooks on each motor especially on 400s.Just unbolt from the donor and bolt to the front and rear of your block.I usually just paint and leave them on the motor after I install it.Good luck.
Old Nov 30, 2001 | 07:17 PM
BigBrownTruck's Avatar
BigBrownTruck
Pulling 302
so Pontiacs are good for something? (kidding) I have loved and used my intake manifold liftplate. The one I have will work on both 2V manifolds and 4V..... Chevy or Ford (haven't had an opportunity to play w/ a mopar) but I don't think it'll fit a Honda.
BBT
Old Nov 30, 2001 | 08:31 PM
Franklin2's Avatar
Franklin2
Pulling 302
captain1997
Sep 16, 2014 05:59 AM
bill divins
Nov 29, 2009 10:45 PM
fordfan302
15
Feb 14, 2008 09:29 PM
NvMyWS6
15
Sep 23, 2006 06:24 AM
tsi9973
Apr 27, 2006 05:43 PM
