"Dana Rear"
Old Nov 11, 2001 | 12:11 PM
Franklin2's Avatar
Franklin2
"Dana Rear"
Old Nov 14, 2001 | 11:23 PM
Bill_s351's Avatar
Bill_s351
"Dana Rear"
Hey guys. How do ya identify a Dana rearend if there is no inspection tag on it? I have never seen one. I just acquired a 70' LTD 4dr for free. I know what an 8" and 9" looks like and this one is none of the above. It does not have a tag on it and I thought it might be a Dana.
Thanks,
Bill
Old Nov 15, 2001 | 05:49 PM
StockMan's Avatar
StockMan
"Dana Rear"
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
I have an ID image on this page:
[LINK:www.members.aol.com/_ht_a/tbeeee/page/Axle-Ratio.html|Axle ID]
[/FONT]
https://www.ford-trucks.com/dcforum/User_files/StockMan/flag.gif
[FONT COLOR="#ff0000" SIZE="+2" FACE="Bassett"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="+1" FACE="Tahoma"]
[LINK:www.ford-trucks.net/users/stockman|Stockman's Club FTE Site]
[LINK:www.67fordtruck.com|1967 F-Series Registry ( www.67fordtruck.com )]
Old Nov 15, 2001 | 09:31 PM
Like M. Fords's Avatar
Like M. Fords
"Dana Rear"
Is your axle a full-floater design? It will about 8 bolts holding the axle shaft on to the hub if it is. On a full floater you can remove the axle shaft without taking the weight off the wheel. If you can do this, then there is a good chance you have a Dana 60 or 70. A Dana 44 rear axle is not a full floater, and has no strength advantage over the 9" which is not a full floater either.
Old Nov 16, 2001 | 10:56 AM
buzzard's Avatar
buzzard
"Dana Rear"
Don't know what the 8" or 9" look like, but do know that Dana 60's and 70's are huge relative to most rearends.
Old Nov 16, 2001 | 03:27 PM
beartracks's Avatar
beartracks
"Dana Rear"
I wasn't aware that Dana's were ever used in Ford cars. I would expect a 9" although there was a Linclon 9 1/".
Old Nov 16, 2001 | 05:14 PM
6t6merc's Avatar
6t6merc
"Dana Rear"
Some of the big cars with small engines used a light duty rear end of the Salisbury (integral) type. That is, there's no drop-out chunk like a 9", but a rear cover like a D60.
Eric
Old Nov 30, 2001 | 04:06 AM
georgiafordman78's Avatar
georgiafordman78
"Dana Rear"
I'm not sure they made the 8.8 in 1970, but maybe thats what it is.
"Don't Laugh At This Truck Mister, Your Daughter Might Be In Here!!"
'78 F250 4x4/302/NP435/NP205
lifted/"35 mudders
'78 F100 2wd/360/C-6/"9 inch
4bbl int+carb
Old Nov 30, 2001 | 11:49 AM
DirtySideDown's Avatar
DirtySideDown
"Dana Rear"
During the mid and late 60's maybe even into the early 70's most of the BIG HP Mopar had a Semi-Floater Dana 60 rear end. Not sure that of the big boat Fords didn't also use it.
Old Nov 30, 2001 | 02:32 PM
Like M. Fords
"Dana Rear"
I wonder what the advantage of that would be? It can't be that much lighter than a full-float design. Easier to check the brakes?
Old Nov 30, 2001 | 02:58 PM
DirtySideDown
"Dana Rear"
>the brakes?
Strenght, strenght, strenght
Same wheel bolt pattern as front,---onr spare to carry
Lighter, no 8 lug hubs
astesedic(sp) looks better. How would you like a set of the big ol 8 lug hubs sticking out of the rear wheel opening of your Hemi Cuda, Super Bird, or 440 6 pak Road Runner????
These alxes were also use in Dodge and jeep i/2 trucks.
Old Nov 30, 2001 | 07:22 PM
BigBrownTruck's Avatar
BigBrownTruck
"Dana Rear"
I have a 69 F100 w/ a semifloating 5 lug Dana Rear....they can be found in Ford Trucks of this era
BBT
Old Nov 30, 2001 | 08:35 PM
Like M. Fords
"Dana Rear"
Personally, I think they would look quite awesome. I would probably drive around without any hubcaps just to show them off!
