Aerostar Ford Aerostar
Help Tranny Failure!!!!!!
Old Dec 28, 2005 | 11:39 PM
Monty06's Avatar
Monty06
when a tq goes bad you should have along with it a front seal problem you have stated no bad color in fluid right. and you also stated replacing the filter. color good and filter new. your tranny does not move at all speaking as an ex ford tech and current advance auto parts worker. i suspect you have a bad vaccum modular valve
with no pressure you can't shift that part shouldn't cost more than 30 bucks.
Old Dec 29, 2005 | 04:36 PM
Bear River's Avatar
Bear River
Former ******
Agreed. I doubt that the tranny is going bad on you. These trannies are tough, but modulators are maintenance items that are meant to be replaced periodically. If they go bad and get neglected, then tranny damage may eventually occur.
Old Dec 29, 2005 | 06:13 PM
lv2race's Avatar
lv2race
You may want to check the modulator vacuum line for cracks or a possible disconnect at the mod and at the manifold.
JSB1
6.7L Power Stroke Diesel
16
Dec 12, 2016 09:36 PM
Truckpilot1329
2009 - 2014 F150
13
Jul 16, 2015 10:11 AM
sonicsaleen
6.4L Power Stroke Diesel
Oct 10, 2010 10:43 PM
laser92awd
1983 - 2012 Ranger & B-Series
Nov 21, 2005 02:10 PM
Savaged1
24
Nov 1, 2003 12:02 AM
