General Automotive Discussion
Eagle Talon valve lifters
Old Dec 25, 2005 | 01:00 PM
JD717's Avatar
JD717
Ok, my cousin brought his 97 Talon over to my place while he's away for awhile in jamaica, so I need some help getting it all fixed up for him when he gets back. first off, the valve train makes a LOT of noise when the engine is running, it sounds like a rocker or lifter or something is hitting the cover internally, I know its not a low oil pressure problem, mainly because I just checked all that, and he's got a mechanical gauge on it. oil pressure reads at 30-40psi.
Old Dec 25, 2005 | 04:10 PM
Ford_Six's Avatar
Ford_Six
Pull the valve cover. Everything's right there, the problem should just about jump out at you. But don't try to start the car with the cover off, it will spray oil everywhere.
Old Dec 25, 2005 | 04:30 PM
JD717's Avatar
JD717
I talked to a mechanic after i posted this, and he suspects it to be a collapsed lifter, I'm told its got hydraulic lifters, and my cousin didnt know he had practically nothing left in the engine. just enough oil to keep the mains lubed and not much else.
H_Talon
Electrical Systems/Wiring
Feb 14, 2013 12:13 PM
mattebury
Feb 5, 2008 08:17 PM
jkorreck
Jul 4, 2004 01:40 PM
talon silvermoon
Apr 25, 2002 10:11 PM
