Timing chain stretch....... Distributor Gear wear perhaps (thinking out loud)..... lots of things Im not thinking of probably
The chain guides wear also, timing gears, well just engine wear period will affect the timing. IMO that on every tune up it's best to check the timing also.
reasons why the timing change
1 mechanical timing , the chain wores out , cam bearings wore out , cam breaks
chain tensoiner breaks , distrubuter shaft wears out , advance springs weaken ,rotor comes lose , gears wear out , lack of proper lubercation
2 electric timing , excessive arching , spark plugs burn down , bad plug wires , rust ,
water , carbon , bad cap , bad pick up coil , bad coil , low voltage , bad computer ,
bad sensors
That should cover a few thing why the timing changes & the distributor hasnt move
I will add a question: What does Ford ignition, with no crank sensor, use as a zero reference for timing? Can there be any error there?
Answer, Top dead Center, and of course there can be error..... A dizzy in 180 off aside from crankshaft position, valve timing can be off, so while your ignition timing may be okay, valve timing may not be.
Of course. I was asking by what mechanism does Ford ignition use to detect TDC, and can a error occur there.
