can anyone help???
Old Dec 24, 2005 | 09:42 AM
BIG-COUNTRY's Avatar
BIG-COUNTRY
Question can anyone help???
my central heat and air unit is freezing up (big clumps of ice around the sides) i was wondering why it do this and how can i fix it??? thanx
Old Dec 24, 2005 | 01:10 PM
preppypyro's Avatar
preppypyro
Turn the a/c off and cranks the heat?
Old Dec 24, 2005 | 01:14 PM
53fatfndr's Avatar
53fatfndr
If you have an emergency switch on your thermostat, you need to switch it to that. We get that ice buildup on occasion.
As I understand it, that will turn off the evaporator and use an electric heat instead...or something like that.
Old Dec 24, 2005 | 02:55 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Sounds like a heat pump.
If so, it appears that the defroster is either bad, or the thermostat/timer on the defroster has gone bad.
In either case. . . to get some heat, either switch to 'Emergency Heat' (all electric heating coils) or, if you can manually switch the defroster on, do that.
Years ago, when I had a heat pump, I had to change the defrost cycle from every 90 miutes, to every 30 minutes. My condensor unit (outside unit) was doing the same thing. . . . ice.
Switched to oil furnace. Man. . . nothing like being warm in the winter!
Old Dec 24, 2005 | 03:23 PM
petes79f150's Avatar
petes79f150
Step 1: Purchase plane ticket to Australia. Step 2: Wait until it's winter in Australia. Step 3: Purchase plane ticket home.
Tedster9
May 2, 2018 11:24 AM
kd0axs
May 19, 2012 06:25 PM
websthes
Feb 2, 2009 11:03 AM
50calmike
Feb 10, 2007 07:39 AM
omni
17
Jan 4, 2005 01:33 AM
