87 302 overheating
Old Dec 23, 2005 | 08:57 PM
clemet's Avatar
clemet
87 302 overheating
I just bought a 87 bronco with a 302 and the guy I bought it from said it would overheat due to cyl #8 having no compression and the timing advancing to compensate. When I drive it down the road the faster I go the hotter it gets. When I disconnect the plug wire for 4 or 8 the engine misses. I have been doing a lot of reading and figuring that maybe I should replace the radiator which has a pinhole leak and the water pump along with the head gaskets. I am just curious if this is what I should do? Would what the guy told me be a possible cause (he didn't seem very mechanically inclined)? What would you do?
Old Dec 24, 2005 | 06:51 AM
ken75ranger's Avatar
ken75ranger
I'd do a compression test first. See where you stand. If it's a brass radiator you can solder the pin hole easy.
steve33444
13
Sep 26, 2014 08:14 PM
rricker629
Apr 4, 2013 06:19 PM
gimmeice3
1978 - 1996 Big Bronco
Sep 30, 2004 12:57 PM
nissanjon
18
Sep 4, 1999 03:53 PM
