speedometer mystery
Old Dec 21, 2005 | 10:10 PM
scottddove's Avatar
scottddove
speedometer mystery
I have a 86 f-150 4x4 302efi aod tranny. Here is what is happening I first get in the truck and all is well speedometer reads correct,further I drive it needle goes down an enentually to zero. After truck sits a few hours it is fine this also affects my cruise control from working properly. It has a cable that turns in the speedometer in the dash and also has a sensor with 2 wires going to it. I changed my truck to a 4x4 and used a donor tranny and transfer case I am guessing it is in the transmission some how cause it did not do this with the other 2 wheel drive transmission. I changed out the whole cable out of the other truck cause they are longer and you have to change it to make it reach. Any ideas as to what is causing this and how to test parts to see what is wrong. thanks for the help scott dove
Old Dec 21, 2005 | 10:21 PM
kermmydog's Avatar
kermmydog
Make sure your gears aren't sliping, and the cable is hooked in solid to trans gear.
Old Dec 21, 2005 | 11:13 PM
rainbowATF's Avatar
rainbowATF
I'm not sure if this applies to your vehicle; but on a 1981 F250 4x4, after I rebuilt BW1345 transfer case, I had same symptom. Apparently the speedometer gear on output shaft is held in place by the yoke. The nut had to be torqued to 150 foot pounds or it slips. Found this out after replacing cable and swapping cruise parts and speedometer head without change.
Old Dec 22, 2005 | 10:37 AM
webster's Avatar
webster
Bad speedometer drive gear????
My 81 4x4 acted the same way. Turned out the drive gear on the output shaft was worn down. It would worked until it heated up. Ordered a new gear from a tranny shop in Vegas. Easy to replace.
4tl8ford
Mar 7, 2014 09:48 PM
limeyellowfellow
May 15, 2012 08:26 AM
schaad25
Apr 15, 2007 11:03 PM
78fordman
Sep 13, 2005 09:49 PM
RaleighDad66
21
Mar 31, 2005 02:24 PM
