edelbrock performer plus cam
Old Nov 8, 2009 | 08:42 PM
J Hodges's Avatar
J Hodges
Here is the link
Edelbrock 2106 - Edelbrock Performer-Plus Cam and Lifter Kits - Overview - SummitRacing.com
I am going to put a new cam and lifters in my truck. It has a basically stock 390 in it except for headers and an edelbrock performer rpm intake and 600 holley. The cam in it is wore out so I am going to replace it and would like something better than stock. I rarely go over 4000 rpm so this cam seems perfect. I just wanted to get some opinions before I buy it
Old Nov 8, 2009 | 11:19 PM
Bear 45/70's Avatar
Bear 45/70
One question, how the hell do you wear out a cam?
Old Nov 8, 2009 | 11:28 PM
J Hodges's Avatar
J Hodges
some of the lobes on it are wore out so they are smaller than the others. Its probaly the original cam
Old Nov 9, 2009 | 10:41 AM
Kennewick's Avatar
Kennewick
Almost afraid to ask a question anymore but here goes. I have been studying cams and would like to know the thoughts behind the comment just because I want to know.
It seems to me after looking into it that cam failure in FE's is rare except at start up.
Old Nov 9, 2009 | 10:53 AM
Kennewick's Avatar
Kennewick
Originally Posted by J Hodges
Here is the link
While your there this might be a good 50 buck investment
Edelbrock 7808 - Edelbrock Performer-Link True Roller Timing Chain Sets - Overview - SummitRacing.com
Old Nov 9, 2009 | 11:58 AM
Bear 45/70's Avatar
Bear 45/70
I've seen a cam lobe get wiped, usually from lack of oil, but I've never seen one "wear out", which implies that something entirely different. A wiped lobe will kill the cylinder it is on making the engine run very poorly, but wear out means, at least to me, that the engine is running OK but is down on power. Sound more like a ring issue causing lack of compression than a cam issue.
Old Nov 9, 2009 | 12:26 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yes, the attitude all around has to GO. Too many newbies getting picked on for asking/saying the wrong thing, and it's not conducive to people getting real HELP for their issues.
Old Nov 9, 2009 | 12:31 PM
Kennewick's Avatar
Kennewick
How does one go about being taken off this forum?
Old Nov 9, 2009 | 12:50 PM
krewat's Avatar
krewat
What do you mean, "taken off"?
If you have issues with anyone or anything on this site, feel free to PM me and we can discuss it in detail.
thanks!
Old Nov 9, 2009 | 01:17 PM
Kennewick's Avatar
Kennewick
I'm ready to move on. I don't like leaving accounts un resolved. Never said I had an issue with anything. I work in a rough environment, I came here to relax. It just isn't happening for me.
Thanks
Old Nov 9, 2009 | 02:42 PM
krewat's Avatar
krewat
Thanks
Well, we can try to change that
As for your account, leave it here. That way we don't get another "Kennewick" and people mistake them for you.
Old Nov 9, 2009 | 02:47 PM
Barry_R's Avatar
Barry_R
Cams wear out over time like any other component. The angle gound into the lobe is only +/- 3 degrees as measured on an Adcole tester - about .0010-.0012 across the lobe by indicator. Once the cam lobe is flat it'll go away pretty quickly - but not usually as dramatically as the break-in lifter type failure since the surface is burnished.
Old Nov 9, 2009 | 05:37 PM
J Hodges's Avatar
J Hodges
my uncle has a set of micrometers and we used them to compare to lobes. 4 of them were smaller.
Old Nov 9, 2009 | 10:07 PM
krewat's Avatar
krewat
Well, that's the definition of "worn"
Out of curiosity, how much different were they? A couple of thousands might be within factory specs for "way back then".
Old Nov 10, 2009 | 11:42 AM
J Hodges's Avatar
J Hodges
about 20 thousands. If you had the mircometer adjusted to the size of the other lobes when you put it on these you could see through them easily
