A/c Heater Control Asembly
Old Dec 21, 2005 | 08:09 AM
HENDEL JR's Avatar
HENDEL JR
Post A/c Heater Control Asembly
MY 1990 E-150 VAN HAS A TEMPTURE CONTROL PROBLEM
I DO NOT KNOW IF IT IS CONTRLED BY A CABLE OR VACUUM MOTOR
HEAT DOES NOT COME OUT
Old Dec 23, 2005 | 10:57 AM
pfogle's Avatar
pfogle
In a 1990 the temperature blend door is cable controlled, there is an outside air vent that is vacuum controlled, and a director door (changes the air flow from floor to vents to defroster) that is vacuum controlled. If you have not heat try tunring the A/C on in the MAX position. If you get good heat then you need to close the outside air vent. In our '88 we just ran a vacuum line from the manifold over to the valve. It should be on the bottom of the HVAC box inside the cabin.
Old Dec 23, 2005 | 11:29 AM
HENDEL JR's Avatar
HENDEL JR
WHERE IS THE PART OF THE CABLE CONECT TO NOW THIS A VAN AND
THIS VERY HARD TO FINED TO LOCATE THIS CABLE WITH OUT TAKEING
THE DASH HALF WAY OUT TO SEE IF WHERE THIS CABLE IS
WHEN I MOVE THE TEMPERATURE CONTROL CABLE FROM COLD TO WARM
IT WILL STLL BE WARM IF THIS VEHICLE HAS A CABLE OPERATED
Old Dec 23, 2005 | 11:31 AM
pfogle's Avatar
pfogle
The easy way is to drop the interior heater box. Take the front panel off of it, and look in there to see if the door is broken. The cable connection should be on the top of the box.
Old Dec 23, 2005 | 01:34 PM
HENDEL JR's Avatar
HENDEL JR
I LOOKED AT WHERE ALL SEE IS A VACUUM MOTOR ON ALL VENTS
dwbaily
1983 - 2012 Ranger & B-Series
Dec 4, 2016 02:35 PM
BLACKHAWK_1989
17
Apr 8, 2015 03:07 PM
TMauro
General Diesel Discussion
Jul 3, 2012 08:03 AM
TMauro
Apr 15, 2012 09:06 AM
