Sponsored by: Real Truck
f-350 bounce
Old Dec 20, 2005 | 10:10 PM
jrbnsn's Avatar
jrbnsn
f-350 bounce
my new 2006 f-350 has a bounce at 48-50 mph. took to shop they can't find the problem. can anyone help? thanks.
Old Dec 20, 2005 | 10:23 PM
99f350sd's Avatar
99f350sd
Whats a bounce? Please describe better. frequency, shake etc.
Oh and welcome to the site.
Dick
Old Dec 20, 2005 | 10:34 PM
jrbnsn's Avatar
jrbnsn
it feels like the tires are not balanced, but the dealer has balanced the tires twice. i can feel the bounce (vibration) in the rearend mainly.
Old Dec 20, 2005 | 10:46 PM
mhoefer's Avatar
mhoefer
I had Revo's on my 2000. Balance problem resolved only by remounting the tires properly, also had to buy new shocks, steering damper, brakes. Problem is that the Revo's have a yellow dot that must be lined up with the valve stem for best balancing, until I had them re-installed by the yellow dot no balance would hold. I also had in the mean time, to replace all ball joints.
Old Dec 20, 2005 | 10:50 PM
fyrhog's Avatar
fyrhog
350 Bounce
My buddy has deisel and it bouces a lot down the freeway.My 350 has a V-10 and has no bounce.It might be the up front weight of the deisel (if you have one) that makes the excessive bouncing.Just my observation.
Old Dec 20, 2005 | 11:27 PM
Big George 150's Avatar
Big George 150
Do you have the 18 Inch wheels with the Continental Tires? I have those on my 05 F-350 and they are the worst tires I have ever owned. I don't care what the dealer does the only way they are going to fix your problem and mine is to replace the tires with a different brand.
Old Dec 21, 2005 | 08:35 PM
BareBones's Avatar
BareBones
Are we talking interstate bouce, from the joints in the concrete slabs?
Old Dec 21, 2005 | 08:59 PM
05bluehog's Avatar
05bluehog
if its a longbed... that interstate bounce is.... T....O...U...G...H......T...O......G...E...T...... U...S...E......T...O...O
Old Dec 22, 2005 | 08:54 AM
jrbnsn's Avatar
jrbnsn
i have goodyear 20" and it has the bounce (shake) at 48-50 mph on new smooth asphalt. the dealer put 4 new tires and replaced 3 rims and it did not change at all. the dealer has duplicated the bounce and now says it is normal?
Old Dec 22, 2005 | 09:57 AM
SteveH-CO's Avatar
SteveH-CO
My '99 did this worst with some wide rims/tires, and it got better with narrower rims and 265 tires, and is almost gone with new tires on stock rims.
The front end of the truck would go up and down as if both tires were oval (and in synch with each other), at 47 mph.
I have a 4WD/crew/shortbed/v10/auto with 123K miles. It's not bad enough anymore to be annoying, but I suspect it's an inherent shake that will be hard to track down.
Steve
Old Dec 22, 2005 | 01:01 PM
BareBones's Avatar
BareBones
BlueHog - Love it..... Good imagery!
mcgyver010101
May 2, 2010 04:30 AM
05f250fx4
Jun 22, 2006 06:58 PM
drfdog
Jan 14, 2006 11:37 PM
bobfl
Oct 23, 2001 08:21 PM
