Wiper Blade problem
Old Aug 24, 2003 | 05:56 PM
55FordLover's Avatar
55FordLover
Angry Wiper Blade problem
Gentlemen,
My wiper arm will not be go down flush to the bottom of the window. They stay up to the left position and goes down to the engine block and back up...how can i change this on my truck....it looks quite funny with the arms up and to the left...like they got stuck....
James
Old Aug 24, 2003 | 08:31 PM
51dueller's Avatar
51dueller
Wiper Blade problem
Have you tried removing the arms and putting them back on at the bottom of the window?
Old Aug 24, 2003 | 09:46 PM
55FordLover
Wiper Blade problem
yes...and they go down into the cowl and back up...scratching the paint already there....it sucks....anybody have any ideas on what i could do for this?????
James
Old Aug 25, 2003 | 09:32 AM
DS02F250's Avatar
DS02F250
Wiper Blade problem
WOW!! I had the exact same problem with my wiper system install. They would either not "park" at the bottom of the windshield (and scratch the cowl) or stop at 12 o'clock, 9 o'clock, etc. I tried taking off the wiper blades and activating the switch. I marked on the switch where "park" would be while noting the full arc of the sweep it makes. This didn't work either! Go figure.
I finally called a shop and asked how to remedy. They said there is a nut you have to adjust. It's on the wiper motor. Also, make sure the wiper motor is grounded real well. My installer gets in this morning 'round 8:00 am, I'll call and ask and send more info if it differs from what I just told you.
BTW, I ended up going with a separate single button "plunger" switch for the wiper fluid and a separate **** for activating the wipers (off-low-high).... and it STILL doesn't park consistently. I guess I'll have to learn to "time it" to get them to park correctly. So, it's still not perfect, but I'm thru messing with it and my frustration level has peaked, so I'll live with it. I guess these old trucks weren't made to accomodate the creature comforts of today.
Butch n Me
Old Aug 25, 2003 | 02:02 PM
55FordLover
Smile Wiper Blade problem
Thanks man....i have been fighting to get them down to the cowl...trying to get her ready for the safety inspection this week so i can register and put some insurance on her....that way i can drive her to the shops instead of having someone follow me on the road with hazard lights....quite frustrating at times...TX is not nice to old trucks either with no paperwork....hopefully your installer can shed some more light on the subject....mines is stuck at the 10-11 o'clock position....sure does look funny...also the pics that fenders sent me from PF2003 shows that the blades can be down in the cowl unless those guys with went new wiper systems.....
James
Old Aug 26, 2003 | 08:36 PM
55FordLover
Thumbs up Wiper Blade problem
GENTLEMEN,
I have fixed those crazy arms and wiper motor...thanks DS59F100 for the insight...that nut was a little bit tricky but i eventually got it going...well the next matter at hand is the doors.....
James
iron1951
Feb 25, 2012 04:39 PM
mantta
May 21, 2007 10:42 AM
ricalbuq
Texas Chapter
Jan 6, 2007 12:04 AM
krautwolf
Nov 6, 2005 11:57 AM
55FordLover
Mar 19, 2004 07:28 AM
