1978 - 1996 Big Bronco
need help! rear window stuck down
Old Sep 29, 2011 | 07:52 PM
76250_4x4's Avatar
76250_4x4
ok im sick of it raining in my bronco since ive owned it. ive searched alot of info on the window motor and havent found what im looking for. my window is stuck down and i need to unbolt it or something to put it up by hand? well this thing has a bunch of mud in it and i cant see clear in the bottom and have no idea what to unbolt. ive tried putting power right to the motor and it dosnt even click. thank you
Old Sep 29, 2011 | 08:33 PM
greystreak92's Avatar
greystreak92
Surprised you haven't found this info because I think the title you picked has been seen at least fifty times in the last five years.
Check my gallery for a parts detail of a typical tailgate. The inspection cover needs to be removed. From there you can access the ends of the regulator arms that half the bottom of the glass. Either remove the tracks from the glass or pop the glides off the ends of the regulator arms. This will free the glass and allow you to slide it up by hand. Be ready to catch the glass out the top of the gate. Once the glass is out you can deal with just about everything in the tailgate.
There is some info on the FAQ site in the Read first at the top of the Forum.
Old Sep 29, 2011 | 11:33 PM
Edgethis's Avatar
Edgethis
If you remove the old motor the regulators will spring up and the window will come up. Im not sure how far up it'll come. You don't want it all the way closed as then you can't open the tailgate.
Otherwise you'll have to stick a board or something in there to hold it up.
billrigsby
Mar 11, 2011 05:52 AM
87wreckerman
Dec 19, 2005 11:56 AM
whoop09
Jun 15, 2005 06:38 PM
PeteD
Jul 28, 2003 03:26 PM
video
Nov 3, 2002 06:35 PM
