New Member, Rearend Question
Hi. I'm a new member, and I'm pleased to have found this forum! I'm going to be putting my '47 1/2 ton back on the road, with your help. I have uploaded a few pics into my gallery, but don't yet know how to provide a link to them...
The biggest issue is that the rear end is frozen - differential fluid has leaked onto the brake shoes, and they've swollen tight to the drums (as a result of my own repair done many years ago...). Anyway, I've been thinking of switching it out to a more roadworthy rearend. Searching this forum, I found reference to bolt-in 67-72 Ford pickup rearends. I think I've located a '72 in a friend's back yard. My first question is, how do I identify the correct rearend, if I'm after one of these bolt-in replacements? My friend isn't sure if the truck is a 3/4 or 1/2 ton. Will that make a difference? Thanks in advance,
John
John
There are no dumb questions, if you want to learn something.
Best to keep searching for the 1/2 ton rear end, they should not be that difficult to find, there were a lot 67 thru 72's made, so......just try to get a complete rear end, it will make life a lot easier, even if it needs re-built this is not a problem as everything is availabvle.
As far as an "adapter", it will depend on the yoke and your drive shaft, in my case I was able to pick up a universal at the local parts store with the two different end caps, other than that it was a bolt in. I did buy the later (67/72) shock brackaets to go on the frame so that I could use the newwe shocks.
Dave
Dave
on
Diff Question
Try to make sure that the engine in the truck that is the donator is a V8. These are the 9 inch rears, and have the same 5 1/2 on 5 bolt pattern, as your 47 had orginally. The same wheels if you are looking for choice fit from 1940-1995, cars/trucks.
A friend of mine runs a 239 Flathead all stock with a 3.25 ratio, and he claims the truck runs great, and does a good job through hills etc. The hills I'm speaking of are through the PA, TN, Appalachan, hope I spelled it right.
Also the choice is very wide-spread as far as different ratios go. As an idea 2.75-4.?, and are virtually indestrcutible. So the choice is great and these are plentyfull. Best of luck to you and Merry Christmas.
Originally Posted by 46fordtruck
Is that center chunk of the F250 the same as a 9" rear? If it isn't then you are limited to only the F250 rear. I always thought the F250 used a different rear.
Gary is correct; nothing from a 3/4 ton will interchange in the 9" 1/2 ton.
Avoid the f-250 model; they are too heavy and wide for your early applic.
Go w/ a 67-72 9" 1/2 ton w/ gears mentioned previously, especially behind
an auto. trans.; great for cruising at highway speeds, plenty beefy, and the
bolt pattern will match your early p-up front wheels/hubs. If using wider rims
and tires, you may have to narrow the left side axle housing to center the
diff. and keep the tires inside the fenders. I had to narrow mine 4-5/16" to
keep my slightly wider tires inside my '36 coupe. Another option is the earlier
57-59 pass. car 9" which are slightly more narrow than the p-ups, but also
have a smaller, non-matching bolt pattern. Use an open drive-line, not the
old torque tube assy.
Have fun with your project.....
Robb
P.S. re gear ratios; Some rear-ends will still have the tag attached on the
front (bolt side) of the diff. Most 60's - 70"s models will stipulate the actual
ratio, rather than a code.
