i smell gas
Old Dec 19, 2005 | 03:36 PM
coreyl302's Avatar
coreyl302
i smell gas
i have a 1991 f 150 and i smeel gas when i turn the heater on i even when i satnd near the engine the truck is EFI so i do not under stand what woudl cuase that any ideas
Old Dec 19, 2005 | 03:45 PM
andym's Avatar
andym
What kind of mileage are you getting? What motor is in the truck? Are there any gas leaks you can see? Does the smell seem to come from anywhere in particular?
Old Dec 19, 2005 | 03:47 PM
coreyl302's Avatar
coreyl302
mileage is really good the truck has a 302 in it it seems liek the smell is coming from the engine compartment
Old Dec 19, 2005 | 08:18 PM
Popa Tim's Avatar
Popa Tim
Check around the injectors, the fuel pressure regulator (even pull the vacuum line off of it - there should be NO gas there), and the Schrader valve on the drivers side fuel rail. Those items all have seals which could be leaking.
Old Dec 19, 2005 | 10:42 PM
framerboy's Avatar
framerboy
I'll add this, because it happened to one of my trucks. Start the truck and then with a flashlight have a real good look at the injectors. I had one with a really small crack that would leak gas, but dry up right away due to engine heat. The constant gas smell drove me crazy for a month or so until a friend ran it down.
Old Dec 20, 2005 | 12:18 AM
e9tac's Avatar
e9tac
Also, make sure your hoses to the charcol filter are hooked up and that the charcol filter itself is ok.
Shadowrider123
Aug 9, 2014 04:25 PM
manolo
Oct 2, 2012 02:27 PM
jpjahn
Jun 20, 2005 04:46 PM
ScottyB
Apr 6, 2003 12:29 PM
mike03
Feb 14, 2003 03:41 PM
