Gas Cap
Old Aug 8, 2014 | 08:51 PM
Shadowrider123's Avatar
Shadowrider123
Gas Cap
When I remove the gas cap on my 64 the gas tank is always under vacuum. There is also a faint gas smell in the cab when the truck has been sitting for a day.
It was not that way on my 66.
Have I got a bad gas cap on the 64?
Old Aug 9, 2014 | 01:53 PM
peter sipp's Avatar
peter sipp
Gas cap troubles
Hi Shadowrider, Have you tightened the clamps inside your cab. On the filler hose to the gas tank???
Old Aug 9, 2014 | 02:46 PM
TBird Larry's Avatar
TBird Larry
Sounds like to me the cap is not venting, hence creating a vacuum while fuel is being sent to the carb.
Next time you drive it open the cap to release the vacuum first, then drive it then when you park it open the cap to release the vacuum then see if you get any smell inside the cab. How much gas do you keep in the tank?
Try switching the gas cap with your 66 to see what happens. Nowadays you can't vent because of the emissions laws on newer vehicles.
In any event I hope you don't smoke!
Old Aug 9, 2014 | 03:46 PM
shortwide's Avatar
shortwide
My 66 has the original painted cap and when the rubber gasket wore out, I replaced it with a gasket from a new, non-vented cap.
I wanted to keep the cap for the original paint, but also because it vents the tank and the new ones that I found don't.
Old Aug 9, 2014 | 04:25 PM
TBird Larry
Check here and you will find original vented gas cap's.
Sacramento Vintage Ford Price is right.
DeadElephant
30
Jul 16, 2019 08:10 PM
Pdxjacob
May 9, 2016 01:57 PM
Sportsterengr
Apr 18, 2016 02:29 PM
skidoorulz
Jun 4, 2015 09:43 AM
babbler
May 21, 2005 05:42 AM
