Emblem came off
Old Dec 18, 2005 | 04:08 PM
ALL BOY's Avatar
ALL BOY
Emblem came off
I had my Diesel emblem come off the front of my 1990 F-350 tuck. But the good news is that I did find it. Has anyone had this happen? Whats a good method to get it back on so it wont come off again. I'm thinking epoxy. Will this work?
Old Dec 18, 2005 | 09:55 PM
chrono4's Avatar
chrono4
im thinking any kind of mix epoxy would be good. just make sure its mixed good. give it ample time to dry, and only use just enough so it doesnt spread out from underneath the emblem.
Old Dec 18, 2005 | 10:07 PM
ssmf250's Avatar
ssmf250
i got two words for you=1. duct, 2. tape, or bailing wire, how bout some super glue, hell try some bubble gum
a two part epoxy should work just fine, i forget but theres actually a special epoxy that is designed for it
Old Dec 18, 2005 | 10:15 PM
BigRyanKP's Avatar
BigRyanKP
how about double sided foam tape that is made for installing emblems. 3M makes some good stuff.
Old Dec 18, 2005 | 10:28 PM
ALL BOY's Avatar
ALL BOY
Hey BigRyan, I think Ford tried the double sided foam tape on it originally. I'm thinking some epoxy might be my best bet.
Old Dec 18, 2005 | 10:46 PM
BigRyanKP's Avatar
BigRyanKP
Yeah it’s too bad that after almost 20 years it finally fell off. Epoxy wont last half as long. Think about it the tape is made to withstand all the shuddering, bouncing, and shaking of the truck, epoxy will harden very stiff and will come off after enough vibration or if someone bumps the panel wrong. I used the tape on my Lincoln and after 4 years its still not going anywhere.
just my .02
Old Dec 18, 2005 | 11:40 PM
ssmf250's Avatar
ssmf250
thats what i was thinking of, its the 3m tape=good stuff highly recommend
or you could go with what i origanally said and just use some duct tape-trust me it will make your truck stand out and be one of a kind-j/k
Old Dec 18, 2005 | 11:42 PM
chrono4's Avatar
chrono4
might as well go with the duct tape, we got a few trucks around here with duct tape fender patches, so youd fit right in.
Old Dec 18, 2005 | 11:51 PM
ford390gashog's Avatar
ford390gashog
you will have better luck using silicone gasket maker form permatex. or they sell silicone adhesive
Old Jan 9, 2006 | 11:26 AM
wassabe's Avatar
wassabe
The best fix is to go to your dealer and order a new emblem. They come with self adhesive backing already applied. Its the cleanest way to go.
Old Jan 9, 2006 | 01:41 PM
Ogriv's Avatar
Ogriv
If you don't want to mess with the emblems falling off, have them reproduced in vinyl.
Old Jan 9, 2006 | 06:06 PM
ALL BOY's Avatar
ALL BOY
Where can I find this dubble sided tape that everyone seems to like?
Old Jan 9, 2006 | 06:08 PM
chrono4's Avatar
chrono4
hardware store
Old Jan 9, 2006 | 06:21 PM
smecomark1's Avatar
smecomark1
Regular two side sticky tape from the craft or hardware store would probably work but it is thicker than the OEM stuff and is white instead of gray. Do not know how much the OEM stuff cost, chances are your local "Custom Parts" shop will have something that will work good to. Epoxy may not do to well due to large temperature variation (dissimilar coefficients of expansions) it will crack.
sgrol
6.7L Power Stroke Diesel
Dec 19, 2013 09:25 PM
Kendall
Jun 17, 2010 10:39 PM
badass75 hiboy
Jul 20, 2008 10:18 AM
NAA_Silent
24
Aug 17, 2003 10:12 AM
