fixxed my horn!
Old Dec 29, 2001 | 04:53 PM
71swissaqua's Avatar
71swissaqua
fixxed my horn!
My horn has worked only off and on for about 2 years. I finaly got around to looking at it today.It was not getting a good ground through the steering column. I'm not sure but I think there is a metal piece inside the rag joint that makes this ground. Does anybody know if this is true.I used a jumper from top to bottom of joint out of the way of everthing to get by inspection tomorrow.
Old Dec 29, 2001 | 06:39 PM
Franklin2's Avatar
Franklin2
fixxed my horn!
I've heard some guys saying there was a strap on the rag joint. It stands to reason, because I do know, the horn wire is grounded to make it blow. The hot wire goes to the horn relay, and then the relay is grounded to activate it through the metal disc in the steering wheel.
Old Dec 29, 2001 | 07:00 PM
jowilker's Avatar
jowilker
fixxed my horn!
Clint I did that to my blue truck and it worked. You probably don't have the firewall to engine ground strap connected. The cab sits on rubber mounts and the column has the rag joint so the ground back to the battery is lacking. Try a wire from the cab to the chassis or to the engine and see if it doesn't work just as well.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Dec 29, 2001 | 08:28 PM
Metro2's Avatar
Metro2
fixxed my horn!
n4gnr
35
Mar 31, 2021 06:39 AM
Strongbad
Apr 16, 2013 05:49 PM
chesire17201
Jan 2, 2012 08:15 AM
40searay
Apr 15, 2008 04:30 PM
76 F250 4X4
Oct 26, 2002 03:21 PM
