Horn Ground Problem
Old Apr 15, 2013 | 04:38 PM
Strongbad's Avatar
Strongbad
Horn Ground Problem
My truck has been sitting since January because the inspection has been out.
Couldn't get the horn to work for the life of me, so Saturday I set about troubleshooting.
Applying power directly to the horn would make it sound, so I knew the horn was good.
I had installed a Grant steering wheel, so I rented a puller and pulled it off, and spent Saturday trying to figure out what was wrong.
I replaced the horn relay, but that didn't do it.
After several frustrating hours, I figured out the horn wasn't grounded correctly.
If I would bridge the brushes with a screwdriver and touch the shaft, it would not sound, but if I bridged the brushes and touched the steering column, the horn would sound.
I finally found a thread on here about grounding the rag joint.
THREAD:https://www.ford-trucks.com/forums/8...rag-joint.html
I cleaned up my rag joint with a wire brush, and that seemed to do the trick. Horn works great now.
Just to be safe, I ran a wire from one side of the rag joint to the other like this:
Hope that helps someone in the future.
After that, I got her inspected and washed her up.
Cleans up pretty good (From about 10 feet).
Old Apr 15, 2013 | 04:49 PM
jowilker's Avatar
jowilker
Did something very similar on my 66. There is a factory ground that can get destroyed over the years.
Good post.
John
Old Apr 15, 2013 | 04:55 PM
gangstakr's Avatar
gangstakr
Is that a picture of your rag joint with ground strap? If so nice work.
Old Apr 15, 2013 | 06:18 PM
JEFFFAFA's Avatar
JEFFFAFA
Thanks strongbad. I think you just saved me some aggrivation. My rag joint is all wet from a power steering leak. Good Job man.
Old Apr 15, 2013 | 09:40 PM
Strongbad's Avatar
Strongbad
No, not my rag joint. This is a pic I found on the internet that I patterned my fix after. Glad the post is already helping out!
Old Apr 16, 2013 | 05:49 PM
flyboy2610's Avatar
flyboy2610
I have a Grant wheel on my '69 F250, I'm going to have to try that. The Horn doesn't work on mine either. That may be why! Thanks for posting that!
Chris Roy
Apr 20, 2019 12:12 PM
Duckmang
Jul 28, 2013 11:40 PM
frigerator
May 24, 2009 06:16 PM
Faltura
Aug 8, 2005 07:53 AM
blk964xbronc
13
Jan 3, 2005 03:04 PM
