help with ball joints
Old Dec 16, 2005 | 06:42 PM
gatorpsd's Avatar
gatorpsd
Need to change all my ball joints. looking for a write up. Like will the axles just pull out or what special tools iI will need. I've gone as far as the spindle,but that is it. any help
Old Dec 17, 2005 | 12:01 PM
barebackjake's Avatar
barebackjake
i dont know of a write up on it. the axles pull right out. you will need a ball joint press to press the new joints in. keep soaking everything in pb blaster, since your in tx the corrosion/rust shouldnt be horrible the old ball joints can be a pain to get out sometimes. you may have to take your knuckles to a machine chop to have them hydraulicly press the old joints out and may as well have them press the new ones in while your there. the only other tool i can think of is a picklefork to seperate the ball joint on the steering knuckle to you dont have the tie rod connected to the knuckles.
Old Dec 17, 2005 | 10:44 PM
psu927's Avatar
psu927
Yeah the the special socket to take the nut that holds it all together off. It will take a lot of beating to get the hub off but it will come. Use penetrating compound. Really good if you have an air chisel. You can rent a press for free at advance auto parts. You have to pay a 120$ deposit but as long as you don't ruin the tool you get all of that back when you take the tool back.
afonda
May 13, 2013 04:08 PM
magnet1
2004 - 2008 F150
Jun 30, 2011 09:24 PM
sedrick38
Feb 28, 2009 11:54 PM
plgebbia
Jun 3, 2008 09:59 PM
agillings
Oct 26, 2000 12:40 PM
