That's got to be a dealer only part unless you get lucky on e-bay.
apcm=auxiliary powertrain control module
aic=auxiliary idle control
For those unfamiliar, it's a Ford in cab control module that you can use to set various idle speeds with to, I believe, maintain battery charge.
BTW, i almost forgot, I got the harness some time ago. If anybody needs the correct harness part# its F5UZ-14A411-AA . Thats the wire harness for the 6 pin apcm (F5TF-12B640-AB actual apcm number)
