where to buy a cam+lifter kit
You can call paw performance, one of their SSI camshafts, has the same specs, with the adv. duration being less, this could mean nothing, as a cam provider can list it as what ever they wish, if its measured at the same point as the mellings camshaft, then this is better.
Listed for $59.95 in my catalog, less lifters.
part number 11319
818-678-3000
You may have better luck getting a clevite camshaft, the one they offer is the same as well, this cam design really got around huh? Northernautoparts . com might be able to help you out with getting a mellings or clevite brand.
part number 11319
818-678-3000
I should point something out...they (paw,ssi, would imagine mellings) list the lobe lift as being .280 int, .295 exh and the lift at the valve, as being .451/.475...doesn't take long to multiply that by 1.6 and realize it comes up short, appears they used a ratio of 1.6101694915254......, why I don't know but thought I would throw that out there, not that a .01 would make that much difference.
Good luck
walkee
37
02-21-2013 04:14 PM
OldRacerGuy
08-16-2008 10:27 AM
