I would NOT use it every oil change, rather ever 2 or 3 changes, about 2 times a year works well. Its a detergent and it will eat internals if over used.
FTE should be recognized for advertising Seafoam. There are more topics on this board about this stuff than anywhere I've ever seen. But then again, thats not how this website works!. Glad everyone is getting the same amount of good out of this stuff as I do. Works wonders doesn't it?
Is it OK to dump the ENTIRE can into the oil and forget about it? Or is it a dump it and wait a few minutes then change oil type of thing?
If you can dump it in and drive until the next oil change what will the Seafoam do to the gaskets and seals. I've got a pesky rear main leak and was wondering if it might help soften and swell the seal to help it fix itself?????
